I’m sure this has been asked before, but I’m slow. I am about to dry wall my new family room addition. The ceiling is a cathederal, 5/12 pitch, 2 x 10’s, 16″ on center. I was going to use 1/2″ material, but my supplier says I should use 5/8″ or I will get “waves” due to the weight and the thin (1/2″) material. What do you think?
5/8 on ceiling always
Rent a lift or make dead men to keep it in place while your screwing it off, makes life much easier.
Edited 4/2/2003 2:33:27 PM ET by CAG
I have to agree with you CAG- I always find it much easier to get away with it if I make like a dead man when I'm screwing off.Kevin Halliburton
"One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard-
1/2 will work fine.
$5 million dollar homes use 1/2" - it will work, but if you want ultra quality, ride the Mercedes with 5/8", and if you want to ride in a Rolls-Royce, 1" thick shaft wall will work too - but it's all overkill.
Or it can look like a wave like most ceilings I have seen that used 1/2" Its subtle but if you look you can see it.View ImageGo Jayhawks
If I paid $5m for a home, I would want at least 5/8 rock on the ceilings.
5/8 is less likely to look wavy, will give better fire resistance, and will insulated from sound better. The only downside is a little more weight and cost.
I would always go 5/8.
Jon Blakemore
If you look in your code book, you will find the answer. It depends on the direction of the drywall to the rafters/joists and the spacing of the rafters/joists.
If you shim the rafters/joists flat as necessary before you start, the job will look nicer.
I have done 26x26 rooms with 1/2" board on the ceilings. I had some 26' I-joists that were off by 1/4" mid span from the 2 adjecient joists. Tapered shims made it all look nice from the top of my ladder.
1/2" , especially with 16" OC....
but then we always furr our ceilings to 16" OC anyways.. so 1/2" is the norm anyplace they furr ceilingsMike Smith Rhode Island : Design / Build / Repair / Restore
5/8" on a garage ceiling with a living space above, 1/2" every where else when the ceiling joists are 16" O.C. I've never even seen anyone consider 5/8" around here...how much more for the rock and hanging if you use 5/8"? Might be worth it for reducing sound transmission...
Hangin' in there
EliphIno!
Used 5/8" for the cathedral ceiling in my MBR for for sound proofing reasons. Was the first drywalling job I ever did, 8/12 pitch roof. If you're going to do it, make sure you use 12' sheets like I did, cause they go up a lot faster and easier. Just be sure to invite 4 of your least best friends to help putting it up.
Jon
Edited 4/2/2003 7:52:07 PM ET by WorkshopJon
For more sound proofing use 5/8 fire code. Its a little denser.
Haven't seem 5/8" regular in decades, all 5/8" here is Type "X" which is the fire code.
1/2 works fine......
5/8th works better.
Better is gooder....and I'd be building myself a gooder home.
So 5/8th is what I'd use in my dream home.
Code Plus builders use 5/8th.
When I gutted my house, I used 5/8" on the walls to - hey, it's my house!
They make a 1/2 inch fiber board , known to drywallers as ceiling board. It and 5/8 has fiber in it and regular drywall does not. You can use 1/2 inch fiber on 16 inch centers , but you would need 5/8 on 24 centers. 5/8s on 16s is a little overkill , except it has a greater fire protection you wont get as high a rating with 1/2 fiber board. Fiber will not sag on 16s.
Tim Mooney
Good call, in washington state I've heard people call it 1/2" ridgid.Reagular 1/2"doesn't meet code for cielings 16 o.c or 24 o.c.
Thanks for all the advice. I think I'll go with the 5/8 and rent a dry wall lift. After all the construction to get this far, I don't have many friends left who can still be bribed, blackmailed or conned into helping. I'll invite the Laker girls over to help, they are always looking for a good time! Thanks,
good plan...
chicks dig drylifts!
should go well for ya.....invite the whole squad.....the odd's gotta work to your favor.
