1/2 wall stability problems
duncmcg | Posted in Construction Techniques on July 22, 2014 08:55am
My wife is opening her own store and rented a store space.  She wanted 1/2 walls to dileneate between work areas and retail areas.  It is an older building with multiple flooring.  I hav done very little framing but I framed the walls and found that when trying to secure them I am having two problems that are most probably related:
1. Plumb- the wall perpendicular to the wall is both plumb and level.  there is a short 6 foot wall that is parallel to the wall and is attached to the first 1/2 wall.  Where the two 1/2 walls are attached it is both plumb and level.  By the end of that wall it is nowhere near plumb.  How do I make the wall plumb?
2. Stability- I have read previous posts on how to stabilize a 1/2 wall ad most requited attaching them to the joists.  IS there another way?  There are multiple subfloors (the building is 200 years old) so if I could avoid cutting through the subfloors I would prefer to do that.
Any advice would be greatly appreciated.
dunc
  1. calvin | Jul 22, 2014 10:25pm | #1
    If you don't want to go down.....
    Go up.
    post at each end of all the walls, carry that up, now you can go through the ceiling, block it and secure the walls.
    deadnuts | Jul 22, 2014 10:32pm | #2
    Your first point reads like a Mensa challenge..but
    duncmcg wrote:
    1.   How do I make the wall plumb?
    At this point, it most likely involves a sawzall and a level.
  3. DanH | Jul 22, 2014 11:31pm | #3
    Yeah, it's far better to run a post up than to go down and try to get a rigid anchorage below.  If you're clever you can make the post running up a "feature".
    1. duncmcg | Jul 25, 2014 07:41am | #4
      go up
      I will try to make it look like a feature as you suggested.  Thanks for your help!
