this is a small job we’re using for rain days and filler work
take out a bearing wall between the kitchen and a family room add-on,
install a beam and half wall with Tuscan columns
and change an exterior door from a 6-panel to a 15-lite
here’s the attic showing the trusses on the bearing wall
and the shoring beam cushioned with 2″ Foamular to protect the plaster ceiling
Edited 4/25/2006 9:51 pm ET by MikeSmith
here's one of our building mover screw-jacks
and an assist from the owner
once we had the beam in place we moved our jacks under , then cut our 4x4 posts and slipped the columns over them before we set the posts
this is going to have a 36" half wall with the columns on it
Edited 4/25/2006 10:00 pm ET by MikeSmith
Edited 4/25/2006 10:01 pm ET by MikeSmith
at the end of the day we had the new door in place,
and we mocked up the half-wall with cardboard so the owner would have a better idea of the finished look
Edited 4/25/2006 10:02 pm ET by MikeSmith
Once again, Thanks.
Live the Good Life in the Permian Basin.
rain again today... as forecast..
so we split up again... Chuck & Mike to the column job.. Roy to the insurance job
for some reason we don't use our bosch scm much.. but it sure is a fine saw.. and the rigid stand is a good compliment
the electrician got the wires down thru the plate and beam yesterday... 3 bits !.. lots of nails.. and the guys framed the half wall with the old ( HARD ) 2x6 we took out of the existing wall
Edited 5/3/2006 10:20 pm ET by MikeSmith
we put blueboard on one side , leaving the other open for the electrician
and here's Atlas holding up the decorative capitals in their final location
Edited 5/3/2006 10:23 pm ET by MikeSmith
Looks like a nice question.
I wouldn't want to piss of the guy in P5 though...
he's pretty easy going... he puts up with my ideosynchrysies ( sic ???)Mike Smith Rhode Island : Design / Build / Repair / Restore
Roy covered this job today... he had to case two openings that were wrapped with corner bead & skim coat plaster
HD sells a 1x5 primed pine that finishes at 4 1/2.... so i figured if we popped the old cornerbead, it would get rid of the flared corners...
sure enough... the wall with the corner bead gone worked just right for the new jambs...we're using a 3 1/2 colonial casing here and the Clam clamps help to make nice miters
Edited 5/4/2006 6:18 pm ET by MikeSmith
Edited 5/4/2006 6:19 pm ET by MikeSmith
this wall had an exterior door in it ( the family room was an add-on )
so when we removed the door and the sill, we had a gap in the tile..... best solution we could come up with was a double marble threshold on top of the existing tile...
next problem was shortening the heat on this wall to get it out of the way of the new column base.. we popped two tiles with a 12" sawzall blade and reset them , drilled a hole .. and the heating guy reconnected the heat
so.. 8' wall : three carps, one super, one electrician, one tile guy, & one heating guy....
sure hope i got all that covered ..
Edited 5/4/2006 6:20 pm ET by MikeSmith
Edited 5/4/2006 6:21 pm ET by MikeSmith
Good tools, good equipment, nice work.....one thing missing.....get in one of the pics so I can see what you look like. It would be nice to put a face to all the pics and reports you do on your projects.
from the paparazzi<G> I need a dump truck, baby, to unload my head
thanks , snort.. i owe u 1.... payback's a beechMike Smith Rhode Island : Design / Build / Repair / Restore
payback's a beechcould it involve lobsters? I need a dump truck, baby, to unload my head
Don't worry about it Mike, all GCs / Builders need to take time out for paperwork.
thanks , snort.. i owe u 1.... payback's a beechDon't worry about it Mike, all GCs / Builders need to take time out for paperwork. yeah, it's tough getting it off your shoe<G> I need a dump truck, baby, to unload my head
Pretty nice crapper, eh tx?A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
Yea, I'll have to send you a pic of one I built years ago, the site was in the boonies where we could not get decent port o potty serivce.
It is just an old Mississippi style outhouse, weathered and grey, with a moon cut in the door. Dig a hole, set it over the hole and keep a bag of lime in the outhouse for post use sprinkling.
I got to tell you Cal. Everytime I see that picture I look right past Mike and marvel at one of the cleanest porta pots I have ever sat in. It sparkles.
Good work.
Doo Dah, Doo Dah.
Your welcome.
Nothing but the best for the breaktime ####.A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
you do realize that you & snort have got bounties on your head for tipifest
but don't worry about it....Mike Smith Rhode Island : Design / Build / Repair / Restore
I'm not gonna drink or eat the whole weekend. LOL
Doo Dah, Doo Dah.
I'm not gonna drink or eat the whole weekend. Good, that'll leave more of the weekend for the rest of us<G> I need a dump truck, baby, to unload my head
I heard Mike is gonna plant a land mine in the outhouse.
Doo Dah, Doo Dah.
Have you seen Andy's pool? I need a dump truck, baby, to unload my head
Good point.
Wake me up before you go-go.
>>>>I'm not gonna drink or eat the whole weekend. LOL<<<<Just most of it ?;o)
The destination is not the point. The completion is not the point. Enjoy today. If you can't enjoy today, then what is the point ?
after the electricians got done, Roy got the blueboard up and did some Durabond where the half-wall meets the old kitchen wall..
then we blocked out for the pedestal base
and started on the cap.. 1x12 poplar top with 2x2 nosing rounded over with a 3/4" radius bit
Edited 5/12/2006 8:31 pm ET by MikeSmith
Edited 5/12/2006 8:32 pm ET by MikeSmith
Roy used biscuits, clamps and the finish gun to secure the nosing
and the finished top
and the view from the family room
Edited 5/12/2006 8:33 pm ET by MikeSmith
that heat on the kitchen side is a real pain.. here's where it would up this morning..
and that is just not acceptable..
so we pulled some fins .. moved the housing to the left.. and we'll fake the column pedestal in tomorrow
Edited 5/16/2006 10:16 pm ET by MikeSmith
Edited 5/16/2006 10:17 pm ET by MikeSmith
Good solution on the heater thing, would've never thought of that.
pretty much finished.. except when we reversed the garage door it put the aluminum exterior threshold on the interior..
so the owner wants it changed.. we cut it out and will insert a marble threshold to fill the gap
here's the rest of it... only thing left is one more coat of joint compound and then the Owner can paint
Edited 5/22/2006 9:21 pm ET by MikeSmith
Edited 5/22/2006 9:22 pm ET by MikeSmith
Mike,Do your clients often paint?Our jobs often don't include painting and it's something that I think we would like to get away from, but maybe it's just a fact of life?
jon.. some do and some don't... if they want to do the painting, i have no objections.
we try to give them tips on how to make the painting easier and better
Mike,
Those columns are too big.
half of good living is staying out of bad situations
rez.. what do you base that on?
Wasn't trying to be funny but was just the first impression.
Seems a little too dominant for the size of the interior rooms to me but really whatta I know.
Was thinking a bit narrower in the diameter is all.
Archy probably designed it that way over concerns with a feel towards room separation, I don't know.
To me their look as a central focus is going to be there regardless if the dias are smaller or not.
I wasn't meaning to imply they seemed gawdy or anything, but just seemed a tad overpowering from a personal view, that's all. Still like the look.
i'll check the notes tomorrow.. i'm pretty sure the choice came down to either 6" or 8" diameter... these are 8"Mike Smith Rhode Island : Design / Build / Repair / Restore
Ok, I admit it, this turned out tons better than I thought it was going to !=0)
the beam required a little more durabond where it meets the door wall.. and there was a structural crack over the door from before we started.. so we taped and faired it View Image
the wainscote is done btween the columns.... still have to figure something for the small areas outside the columns
Edited 5/16/2006 10:18 pm ET by MikeSmith
Mike how do you like those Clam Clamps? They look nice but with a price. What kind of holes do the pins that tighten the miter leave?
I was looking at those but wasn't to sure about the possible holes left over from the pins.
Are the pin holes noticable, easily repairable? I only golf on days that end with a "Y".
stilletto... the guy that invented the clam clamps thought about the holes
you can remove the pins for those occasions when you absolutely don't want any pin holes ( like stain work that is in your face )
you just have to be a little more careful in setting the clamp without the pins.. also you can remove like 2 out 3 of the pins
as far as the clamps go.. they are pretty great and they pass the Roy test.. if he uses a tool more than twice.. it's a good tool for fuss budgets... Roy is a fuss -budget
for prodution / painting work ... the clamps are great and the pin holes are easily fillable
if you work with stained material and you use "stain putty " the holes are easy to fill.. either way, they give a great miter with a glued joint or a biscuit / glued joint
i bought one.. tried it .. and bought another one the next year for the pair
Mr. Chestnut ( can't remember his first name ) is one of those guys we should be supporting and encouraging ... so buying his clamps is a GOOD thing
Edited 5/31/2006 8:25 pm ET by MikeSmith
Thanks for the reply Mike I've been thinking about those clamps for three days straight. Wasn't sure about the pin holes. Now I know.
Do you biscuit the joints like they show on the website or clamp and glue?
most times i clamp & glue... Roy biscuits & gluesMike Smith Rhode Island : Design / Build / Repair / Restore
Well they have yours and Roys blessing and my tool addiction is needing a fix so I'm going to buy some. ThanksI only golf on days that end with a "Y".
Clamp, glue, 5/16" staples in the back like Gary Katz recommends.
Easy, fast, secure.
Go.Troy Sprout
"Don't forget the screws"
Mike, did you ever get a finished pic of this one?
"All the knowledge I possess everyone else can acquire, but my heart is all my own." -- Goethe
gotta go back and finish some details.. and they've finished painting... so should be goodMike Smith Rhode Island : Design / Build / Repair / Restore
FYI it's Jim.
Are you down with OPP?
I thought I'd chime in to agree with Mike.
I've never used the clam clamps so I Can't attest to their value but I have been impressed with Jim Chestnut's ingenuity and forethought.
His website is loaded with good tips and even some videos. I expect that we will see more great tools come out of his machine shop.
I agree.
Also, he's very helpful on JLC's finish carpentry forum.Are you down with OPP?
