1/8″ Underlayment?
DonCanDo | Posted in Construction Techniques on September 5, 2009 12:37pm
I laid commercial vinyl tile over hardboard which I now know was a mistake.  There are a few spots that are lifting.  I knew it wasn’t the best choice, but I didn’t have room for 1/4″ ply.
I may be able to get by without replacing the entire floor, but to do so, I would need 1/8″ underlayment that is moisture resistant.  Any ideas what I can use?
And if anyone needs to chastise me for using the wrong material in the first place… well, I already know that, but don’t hold back.  I deserve it.
  1. rlrefalo | Sep 05, 2009 12:42am | #1
    on commercial jobs they always used dash patch. They mixed it with asphalt cutback adhesive.
    What lifted ? the masonite or the tile from the masonite?
    Rich
    1. DonCanDo | Sep 05, 2009 02:03am | #4
      I haven't seen it yet, but from the description, I'm pretty sure it's the masonite.  If it were the tiles, they would be cracking and they're not.
      I used 1" narrow crown staples every 6 - 8 inches and even closer on the seams so however unlikely it seems, they must have pulled through.
      1. Piffin | Sep 05, 2009 01:31pm | #5
        You'd want wide crown every 4" on 1/8" masonite and glue would help too.The pattern you describe is fine for normal 3/8" underlayment but way tooo far apart for 1/8" and masonite is famous for wrinkles and puckers with changes in environment
    IMERC | Sep 05, 2009 12:42am | #2
    in one of the BB's I saw sheets of what looked like Baltic Birch stamped "underlayment"...
    Maybe???
    WOW!!! What a Ride!
  3. Piffin | Sep 05, 2009 01:42am | #3
    float in a floor leveling compound?
  4. DonCanDo | Sep 24, 2009 01:16am | #6
    Here's an update:
    I removed a 4' X 8' section in the middle of the room.  It was the only place where tiles were lifting.  As I suspected, the narrow crown staples had pulled through the hardboard.
    I found a place where they carry 1/8" luan and that's what I used as a replacement.  It's still not the right underlayment, but as I said earlier, I didn't have room for 1/4".  This time, I used staples just about every inch.  I pity the next guy (which just might be me) who has to replace the floor.  At least I didn't glue it down, which I was considering.
    It took me most of the day just for this one section, but at least it's done... for now...
    1. Shep | Sep 24, 2009 03:22am | #7
      Hey, Don-
      I figgered it was you when I read the thread title <G>
      Now that its too late- could you just have hand nailed the masonite with some 4D ring shank nails? The heads on those nails would pull the masonite down tight.
      I also wonder if we had the pressure on the compressor set just a little too high. Obviously, there isn't a lot of room for error when using 1/8" material. It may have been better to leave the staples a little proud, and hammer them down.
      Aa much of a PITA it is to re-do work, at least you're done.
      I know, hindsight is great. LOL
      1. DonCanDo | Sep 24, 2009 05:31am | #8
        If I could have removed the tiles from the underlayment without destroying the underlayment, then yes, ring shank nails would have worked.
        What I did was to remove a large section of tiles/underlayment slightly smaller than the next full tile.  That left me with about 3" of tile still adhered to underlayment.  I was able to remove 3" pretty cleanly with a large putty knife, but I wouldn't have been able to remove a 12" tile cleanly.
        Overall, I probably wouldn't have had any problems if I had used about 3 times as many staples as I did.  A wide crown stapler would have been added insurance.
        The lesson I take from this is to be even more leery of deviating from tried and true practices.
        Oh yeah, I learned one more thing... hardboard is just a convenient method of getting rid of excess recycled paper by dumping it back on the consumer.  The only practical use for the stuff I that I can think of is protecting floors on demolition projects where it doesn't need to last longer than the project itself and is immediately disposable.
          Dam_inspector | Sep 24, 2009 05:34am | #9
          My house was sided with it, and my garage doors have panels made from it. I tend to agree that paper is a poor building product for a wet environment.
