1″ stapler enough for 1/2″ engineered wood?
emaxxman00 | Posted in Tools for Home Building on June 24, 2010 01:07am
I have my dad’s manual Portal Nailer (that shoots a t-head nail) that I used to install 1/2 engineered hardwood flooring in my dining room.  Unfortunately, there were a few places where I didn’t have the nailer perfectly square with the wood and upon hitting it, I knicked the finished.  I now need to install the same hardwood in my family room.
I was considering getting this Bostitch flooring stapler:
http://www.amazon.com/Bostitch-LHF2025K-Engineered-Hardwood-Flooring/dp/B003BVJU38/ref=wl_it_dp_o?ie=UTF8&coliid=IMEJWWTBWDOO8&colid=3A1I8UN552MVF
It’s designed to not require any hammering which should help with preventing damage but it only shoots a 1″ staple.  Even though it’s designed for 1/2″ flooring, the 1″ staple doesn’t seem sufficiently long enough to me to provide the hold needed.
Is a 1″ long staple long enough to hold 1/2″ flooring down?
My other choice is to either buy a used air powered nailer (and then sell it off) or get the Harbor Freight model.  Renting wouldn’t make sense as I’m so slow, I could buy the tool by the time I’m done with the rental.
    MarkH | Jun 24, 2010 07:05am | #1
    Engineered flooring does not require the same strength of fastener as solid wood.  I believe that stapler would be fine, even for 1/2".
  2. BigBill | Jun 25, 2010 10:42pm | #2
    Is a 1" long staple long enough to hold 1/2" flooring down?
    What does the floor manufacture spec?  I don't think that I have ever seen a manufacture spec less than an 1.5 inch staple.
    If you think that you will so slow that you could buy rather than rent by all means buy.  Buy a used power nailer on EBAY and sell it when you are done with it.
