11/16 Plywood
DonCanDo | Posted in Construction Techniques on May 11, 2006 01:19am
I just patched a floor that has 11/16 plywood.  I used 3/4 (which is actually 23/32).  The 11/16 is closer to an actual 21/32, so the patch is about 1/16 high.  No big deal since it’s getting covered with carpet, but I was just wondering if 11/16 is/was common and if it’s even available anymore.
-Don
  1. rez | May 11, 2006 01:59pm | #1
    Sounds like 2x4s with their 1 5/8s...no wait...that's 1 1/2...no wait....1 7/16ths???
    be what's with that?
    half of good living is staying out of bad situations
      IMERC | May 11, 2006 02:02pm | #2
      put it together ... then measure..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
      1. rez | May 11, 2006 02:39pm | #3
        Thought you were going to say to go get a new tapemeasure.
        be 1, 2, or 3 little metal rivets on the dohicky end of the tape
          IMERC | May 11, 2006 05:37pm | #4
          bondo...
          Rock Hard...
          Caulk...
          leveler...
          wht bother with a tape measure... Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
  2. junkhound | May 11, 2006 05:45pm | #5
    Much of the plywood (BS5565 spec baltic birch) I have is 1-3/4 centimeters thick (off pallets used to ship aircraft rudders from Ireland)
    1-3/4 cm is pretty close to 11/16.
    1. JohnSprung | May 11, 2006 10:26pm | #6
      1-3/4 cm = 0.6890"
      11/16"    =  0.6875"
      One and a half thousandths is plenty close enough for most machine shop purposes, let alone woodworking.
      -- J.S.
    2. DonCanDo | May 12, 2006 12:48am | #7
      That would explain it, but the stuff I saw was not baltic birch.  In fact, it looked like ordinary BC plywood.
      -Don
Two Ways to Test Windows
  • The New Old Colonial
