15″ hitachi Miter saw
cabman | Posted in Tools for Home Building on November 19, 2005 06:27am
Does any one have any experience with a 15″ hitachi miter saw?
Good , Bad, Indefferent.
Anything appreciated, Thanks.
Darren
  1. rasconc | Nov 19, 2005 07:31am | #1
    Spotted that tonight in Amazon catalog.  Looks pretty awesome along with the $149 blade price.  Think Hitachi stuff is pretty strong.
  2. Jay345 | Nov 19, 2005 03:00pm | #2
    I have had one for 15 yrs. It still cuts true despite the abuse it has taken, It is a beast, hard to move around [I keep it in the shop these days ].
  3. BilWil | Nov 19, 2005 07:48pm | #3
    Use one owned by a stair builder.  It is accurate and strong.  It is heavy and clumsy to move, but it does an accurate job on wide stock.
  4. migraine | Nov 19, 2005 09:32pm | #4
    I've had one since 1989 and it's still running on the same brushes.  The brake is getting a little worn.  Becuase of this, I don't let anybody use it but me.  The biggest problem I've with it is the protractor tape is easy to knock off /bump when carring it.  I've replaced it once and it has been ready for another replacement for quite a while.
    Great for doing large crown
    I would definately buy another
    1. CAGIV | Nov 19, 2005 10:17pm | #5
      What are the main advantages over a 12" slider?
      1. RW | Nov 20, 2005 01:59am | #6
        it's not a slider. It's mostly a depth of cut issue for large stock or cutting larger crown profiles."If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man." - Mark Twain
      2. migraine | Nov 20, 2005 02:09am | #7
        I find that it is alot easier to lay the crown in the "trough" the way it sits on the wall/ceiling, upside down, of course.  This takes out the guessing as to the settings of compound angles.  But then again, this is the way that I was taught.  Easy to crown out a room, especially when the iside and outside corners are not 90 degrees
        1. cabman | Nov 20, 2005 05:18am | #8
          Thanks for the responses.
          I have been doing a tall crown that is just a little too tall for my 12" delta. This happens once or twice a year, and every time I say I'm going to buy it.
          Thanks again, Darren.
Picture-Perfect Pergola
