15,16, vs 18 gauge nailers
alrightythen | Posted in General Discussion on June 22, 2006 10:24am
I’ve used my 18 gauge nailer for my interior trim work. just curious what you guys use your various nailers for.
I just picked up a 16g nailer for some light exterior trim work. I am wondering what situations would I want to be using an 15g
what do you like to use and for what.
  1. davidmeiland | Jun 22, 2006 10:43pm | #1
    I use a 15 for all casing, base, etc. I use a brad nailer occasionally for small stuff, with either 5/8" or 1" brads that I think are 18 or smaller. In my opinion 18 is way too small for typical trim.
  2. Brian | Jun 23, 2006 12:42am | #2
    15 for almost everything, 18 for tiny stuff, some shoe molding etc.  16 - doesn't get much use.
    Plus the 15 is angled, so I can reach into tighter spots.
    Treat every person you meet like you will know them the rest of your life - you just might!
  3. Shep | Jun 23, 2006 02:27am | #3
    a 15 ga. is the only gun I'll use to set door jambs; I use 2-1/2 " nails for that.
    I feel an 18 ga. doesn't have the strength, especially since they're only 2" long.
    1. Tomrocks21212 | Jun 23, 2006 02:30am | #4
      I concur. Even then, I feel like I'm cheating. Nothing like a handful of 10d finish nails to keep a jamb in place!
      I use the 15 always, unless a smaller gauge is more appropriate.
  4. gordsco | Jun 23, 2006 03:55am | #5
    I use 18ga for almost all interior trim. I also back glue casings to the wall but not to the jambs.
    16 ga for setting 1X trim, interior door jambs, stair treads and nosings.
    My door jambs also get a 3" screw through the top hinge mortice before the hinge goes on.
    I use alot of glue, Yellow and PL-400, PL-Premium for wet areas, the brads hold it in place untill the glue sets.
    Narrow crown stapler for subfloor, cabinet backs, drawer bottoms, cleats.
    My 23 ga pinner also gets a suprising amount of use and I often run a second hose to keep it handy while setting crown or stair rail miters
    I don't own a 15ga but would consider one if I was doing alot of exterior trim.
    May neighbors respect You, and troubles neglect You.
    Gord
    NickNukeEm | Jun 23, 2006 04:11am | #6
    15 ga angle gun for just about everything interior.  It's used so much I recently bought a brand spanking new Hitachi to use in addition to the older Bostitch.  Although I have a 16 ga. Senco, I only pull it out to appease my conscience for getting it in the first place.  18ga. brad nailer for pinning OS miters, small stuff.
    "I am the master of my fate, I am the captain of my soul."  Invictus, by Henley.
