16″ oc for interior walls or still 24″oc
I framed the exterior of my house with 24″ oc, advanced framing. I have a few interior walls to build and I was curious if there are pros or cons to going 16″oc or 24″ oc for the interior walls? I will be hanging cabinets of course and there will be tile backsplashes, etc.
Christian
1/2” drywall hangs 16” on center. 5/8 can span 24” on interior walls. That’s something to consider. I’d recommend blocking for cabinets etc. so spacing is not an issue there. Less wood at 24” on center, less cost, faster installation. Lots of wins there.
No reason why you couldn't continue with 24" OC framing provided you have adequate blocking in place for future cabinets, decorative hangings, TVs, etc.
I recommend using LSL lumber for walls that support cabinets or tile because they're dead straight, stable, and quick to install, especially @ 24" OC. If you go this route, get a few extra LSLs for blocking purposes so the wall moves at the same rate and you don't end up with twisted or gapped dimensional sawn lumber as your blocking in an otherwise perfectly flat and true wall.
Thanks for the ideas, with so few linear feet of walls I think I'll go with 16"oc.
I’d do 16” on center anywhere you’re hanging cabinets or tile it’s sturdier and easier to anchor heavy stuff. If it’s just a partition with no big loads, 24” is okay, but I like 16” for the peace of mind.
