18 ga brad nail vs 18 ga staple
bobl | Posted in Tools for Home Building on June 21, 2006 07:28am
been thinking about a narrow crown stapler.
looking at them, they seem to be 18 ga. when I look at an 18 ga brad, it doesn’t seem like it will be much of a staple.
Is an 18ga brad and an 18ga staple the same size diameter?
Ive pulled some narrow crown staples out of some lattice, and they seem thicker than the brads.
bobl          Volo, non valeo
Baloney detecter
  1. FastEddie | Jun 21, 2006 09:06pm | #1
    Repeat after me ... a pound of feathers weighs the same as a pound of lead.
    The holding power of a stple is greater for two reasons: two legs as opposed to one, and the "head" of the staple does not pull through the material nearly as easily as the small head of the brad.
    1. Jer | Jun 22, 2006 01:46am | #2
      Repeat after me.
      I will listen to what Fast Eddie tells me because he's right.
      Get both guns, they're cheap enough.  Different applications is all.
    2. JulianTracy | Jun 22, 2006 04:12am | #3
      Also,I'll add that the staples usually angle themselves in a bit, increasing the holding power quite a bit.It's actually amazing how much they do hold.JT
  2. gordsco | Jun 22, 2006 04:57am | #4
    Narrow crown stapler shoots max 1¼"?
    18 ga brads 2".
    If your building crates, get the stapler.
    If your trimming a house, get the brad nailer.
    May neighbors respect You, and troubles neglect You.
    Gord
      bobl | Jun 22, 2006 06:13am | #5
      I have a brad nailer (18 ga) and am thinking of getting a stapler.When I look at staplers on line, they all seem to be 18 ga.when I look at the staples used to make lattice it appears that the stapels are larger than 18 ga.Hence the question, is an 18 ga brad and an 18 ga staple using the same measurement in reference to gauge?
      Baloney detecter
      1. ccal | Jun 22, 2006 06:47am | #6
        They make staplers in several sizes. Most larger staples are used in industrial applications though. Not very popular outside of manufacturing markets. Like the people who make lattice.
      2. FastEddie | Jun 22, 2006 05:59pm | #7
        I think there's three basic stapler sizes: narrow crown, medium crown, and wide crown.  And I think the wire guages are different too.  But an 18 ga brad is the same diameter as an 18 ga staple.
Picture-Perfect Pergola
