about a half block west of our current job is the old North Light..
the Owner had us in to look at some work… there is an elegant staircase that turns 180 degrees to get to the 2d floor leading to the light tower on the NorthEast corner..
the tower above the 2d floor was removed years ago when the decommissioned the light
anyways.. this is one very nice looking stair… no way would it meet code today… the top of the rail is only about 24″ above the nosing and a few other things.. but the stair is very easy to climb and everything seems to feel perfect..
here’s the first step and the turn to the right
and a view of the whole flight from the top
How was that curved handrail made? Is it laminated strips of wood like it would be made today, or something else?
no... it's not laminated..
here's some more views.....
the newel...
and the turn viewed from the top
and my knee to show the height of the rail above the nosing
Edited 4/11/2005 10:53 pm ET by Mike Smith
Edited 4/11/2005 10:54 pm ET by Mike Smith
Edited 4/11/2005 10:55 pm ET by Mike Smith
And think of the work that was done ALL by hand.
I like the way the first tread was cut to fit around the newel.
And the way the window trim was cut so the third tread could slide under it and on top of the window sill.
Isn't it nice to be admiring somebody else's work 115 years later? I hope that the guys that we have all met here, at BT, can have there work admired equally as well 115 years from now.
You say that the railing is short. But if you stop and think about it, when you climbed those stairs your hand was out in front of you as you slid it up the rail. Using the railing to help pull you up the stairs. This would put the railing at a comfortable height. As you came down the stairs, you more then likely didn't use the railing.
Please tell the guy that allowed you to come in and take those pictures that we say "Thank You". for sharing that beautiful piece of art work with us.
DaneI will always be a beginner as I am always learning.
Dane,
The profile of the rail would have been carved in sections and then pieced together. Back then the chunks of wood that it took to get that kind of shape would have been a lot less expensive.
-zen
Is it walnut? I just removed a rail that has the same profile and color that had been trashed in a rental. I resold it and reinstalled it in another house (the rental owner wouldn't pay for repair work--rental got a capped 1/2 wall).Edit to add: I just built up a casing to match the one used in those pics for another 1890's house. I'll take some shots of it this week.
Edited 4/12/2005 8:11 am ET by basswood
I love the curved skirt....mmmmmmm skirts......."If 'tis to be,'twil be done by me."
I transplanted a same profile and color rail into my place a few years back. I'd like to know what wood it is also. Could it be a mahogany?
I took liberty of lightening some of mike's pic up a bit to show a little better detail.
sobriety is the root cause of dementia.
Very good detail.
Everyone thinks of changing the world, but no one thinks of changing himself. -- Leo Tolstoy
I think that the last one was bass wood, but I am not sure if I have the correct spelling.
thanks for highlighting those..
it's the handrubbed finish that brings out the beauty
I see the wavy lines on the trimcap there.
I take it that is not the camera lens but the carpentry intention in design and adapting to the sway in the plaster walls?
be seeing double
Yeah, I'm wondering if that could be rotated.
