We were quoted $70,000 to fix our basement walls (stone) either with lifting and replacing or installing bracing system. However, we can’t afford either. What options do we have?
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
