I have a Standard Devoro two piece toilet that needs a new fill valve. The tank lid is stamped May 21 1926 F4082 166. The current valve is a Cesco brass valve, I think a Burlington Model 20, with the arm and plastic float ball. Can this be replaced with a Fluid Master type of valve with the sliding collar float? Thanks in advance for your help.
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
I do not know, but it ought to work if the hole for the valve is in the bottom left of the tank and is about 1" diameter. The height on a retrofit Fluidmaster valve is adjustable. I did a toilet from 1917 once. It is amazing how far back things were standardized.
Bill
You can use just about any universal fill valve on these- the flush valves are a different story (must use a "Douglas" style brass flush valve). I have a "Standard" wall mounted tank toilet from 1927 and have replaced the fill valve with a universal fill valve with no float from home depot (sorry- can't remember the brand off hand..). http://www.DEABATH.com has harder to find repair parts like spuds and flush valves.
My Standard brand two piece toilet is a little newer, I think around 1935, but I had no problems installing a Fluidmaster valve.
Thanks for the quick responses. Looks like plastic is going into that tank.
