1950’s recessed lights
| Posted in Construction Techniques on December 11, 2005 06:48am
my house was built in 1958 and it had old recessed lights in all 3 bedrooms that only had 1 bulb in them very dim. i removed them  and put ceiling fans in that spot. it covered the area good and you cant tell there was a recessed light.
but my  problem is i have two in the kitchen one is 8 inches and 12 inches square. it has weird ceiling texture i dont think a can duplicate. any suggestions?
 thanks doug
    Matt | Dec 11, 2005 03:23pm | #1
    Ceiling medalion?
    1. DanT | Dec 11, 2005 03:38pm | #2
      Yeah, a medalion defineately.  I have done this a few times.  Any decent home improvement store will have them in various sizes and shapes.  DanT
  2. calvin | Dec 11, 2005 03:43pm | #3
    We had the same problem in a church office area they changed over to daycare.  The box is bigger than the trim area of the lens holder.  They didn't want to go to the expense of removal and replacement.  You don't want to increase the wattage past the stated limit.
    We sprayed the inner housing with a gloss white and cleaned the lens.  Amazing increase in brightness.  If you don't want a medallion.
    Quittin' Time
  3. VAVince | Dec 11, 2005 05:56pm | #4
    I ran into this probblem before. I removed the light fixture and installed a new fan rated box. I then used a 3/4" piece of oak (or what ever) plywood large enough to cover the hole and cut in a octagon shape and banned the edges. I thought it looked pretty good. Beats the heck out of trying to patch texture ceiling.
