Any sources? I got a 7″ diamond blade w/1″ hole, wanna use it on a 5/8″ arbor.
Thnx.
What about having a local machinist make one? Good ol American Steel and wouldn't cost you more than 20 bucks.
Hey Sphere, harbor freight sells a card of bushings. Not bad for 1.99$
HF part/sku number p1444
Webby
Darn, thats where I got the blade!!!!Thanx, I was gunna return it, now I'll just go back an look for the bushings. Maaybe I can find a bushing for a saw blade to fit the Stihl weedwhacker, I tried making one from a washer, it wasn't fun. As an aside,They hide away the MM blades there I noticed this morning.Spheramid Enterprises Architectural Woodworks
yea they lock em up here too. bought some and straight out of the pack they were duller than my oldest mm bladed with no teeth
Do they hide em in with the drill bits?
I don't know, they were hidden.Spheramid Enterprises Architectural Woodworks
Yeah I just bought the bushings a day or two ago. Thats how I remembered.
I noticed that the bosch blades fit the HFmm they look nicer. They are graduated to give you an idea of depth when you are plunge cutting.
I have a job coming up where I might get to try out the HF grout blade, the 12.99 one. Webby
Confession time, I bought the HF MM, I already have the dremel, and had the Fien since about 1990...arrrgghh.Spheramid Enterprises Architectural Woodworks
Keep a moon blade on one, a scraper on another, and a flat blade on the last one.What do you think of the HF one (considering the low cost). I got one and it seems pretty good, but I haven't used any of the name brand types.
Didn't plug it in yet, just put the moon blade on it.
I have a st. blade on the Dremel, and Homemade on the Fein.One will live in the shop, have yet to decide which goes where. I had the fein so long , probably it will stay home.Spheramid Enterprises Architectural Woodworks
My multi tool is the only thing I have bought at harbor freight with a motor, except for a compressor that got stolen before it had a chance to burn out.
About the same here, air tools aplenty and one comp. And an HVLP Sprayer for the wife. oh, a slew of cheapo grinders that won't die.Spheramid Enterprises Architectural Woodworks
I bought an air impact wrench there that would spin, but not impact. Took it back and got another, same deal. Just got a refund. I guess you can't get it all for $15, but I thought it might at least work for a little while.
Kobalt die grinder from Lowes, hissed all the time, 30 bucks.
HF 5.99 on sale, runs like a champ for 2 yrs now. Go figga.Spheramid Enterprises Architectural Woodworks
someone on here mentioned the other day on here that sears blades fit the mm
I don't have the star style, mine was sold a just a sander and they had a few blades back then. I'm sure one could whittle the pins off a HF or Dremel and use just about anything. Or something like that.Spheramid Enterprises Architectural Woodworks
The pins on the HF will push back easily. Just put on a blade thats not indexed correctly.
Oops was going to include a link and hit post.
Here you go.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search
Oh, the freaking link doesn't show up- just type in p1444 in the search by number box.
Webby
Edited 10/20/2009 9:11 pm ET by webby
did you find a bushing yet? heres a place i orderd some from.
http://www.toolstoday.com/nsearch.aspx?keywords=amana+bushings&x=17&y=8
not as cheap as hf,but i don't think they had a a 1 to 5/8 when i was looking.
the older i get ,
the more people tick me off
Yeah, I got the HF ones, need to use 2 to get from 1" to 5/8ths, but I've not done it yet.Spheramid Enterprises Architectural Woodworks
http://justsawblades.com/systimatic/accessories.htm
BUSHING SPECIFICATIONS
PART# INSIDE DIA OUTSIDE DIA THICKNESS PRICE
35937 1/2 5/8 .058 4.99
35934 5/8 1 .083 4.99
35939 3/4 1 .083 4.99
I used to have some Freud blade stabilizers too, before the fire, I'm gonna combine an order I think if I can find them at the same place. They were just big alum washers basically, but dampened harmonics considerably when using thinkerf blades.
Guess I ougtta measure the blade body thickness for the bushings first.Spheramid Enterprises Architectural Woodworks
I think the stabilizers would be a good idea, especially with having to use bushings.
Ayup.
I had a bushing somewhere, but it got mixed up with misc. washers I fear. It was for a Chainsaw toothed 12" dia. blade for a tennon maker dohicky I had. Scary Mo-Fo.
I think I still have the blade somewhere, I've not seen it in awhile, see if I can't dig it up and post a pic. It was called a Gator or something like that, green and black.Spheramid Enterprises Architectural Woodworks
calll your local saw sharpening sop. they should have them in stock. There should be no need to stack bushings.
for future reference: http://www.ballewsawandtool.com/
Edited 10/24/2009 8:42 pm by migraine
