1×6 Redwood Decking?
DougR | Posted in Construction Techniques on June 16, 2005 04:41am
I have a small (12×20) deck project in mind and was originally considering using 5/4×6 ipe deck boards. However, I found a source for recycled 1×6 redwood boards for about 25 cents a linear foot – about 1/10th the cost of ipe.
The redwood is 50-year old 1×6 t&g interior paneling – vertical grain, clear, about 16 growth rings per inch. All heartwood. Very nice stuff.
Any reason this would not be an appropriate decking material as long as I frame my joists 12″ o.c.?
Would it be foolish to install it as t&g with a slight pitch instead of ripping off the tongue and spacing the boards? Would eb-ty fasteners work with 3/4 thick boards?
Thanks for your advice.
-DougR
  1. davidmeiland | Jun 16, 2005 06:41am | #1
    With redwood like that I'd find an interior project for it. It will definitely die faster is you install it as T&G... I'd go with 3/16" gaps or even larger.
  2. Gumshoe | Jun 16, 2005 08:52am | #2
    Even at 12" o.c., I would not be comfortable with 3/4" thick redwood decking.  No way.  And the water between the boards has to have an escape route.  Doesn't matter if there is a slope or not, unless the slope runs parallel to the boards.  The whole thing sounds wrong to me.  Just my opinion.
    Edited 6/16/2005 1:57 am ET by Huck
    Sphere | Jun 16, 2005 02:30pm | #3
    I believe you could do ALL of the above. Personally, I am uncertain whether 1x6 would not cup some if ya went T&G. I'd be inclined to waste the edges and space them or just remill the T&G on the slightly narrower board that have fresh edges.
    When you say recycled interior paneling, I envision ragged edges from the uninstall.
    Insert your favorite George Harrison song  HERE.
  4. piko | Jun 16, 2005 04:29pm | #4
    I have laid 1x6 cedar on 16" ctrs and it's tolerable...hardly more than you'd expect, and as stiff as 5/8" subflooring (!). 12" o/c would do...but it's almost sacrilegious to use such good stuff! Don't lay it as t&g, tho.
    cheers
    ***I'm a contractor - but I'm trying to go straight!***
    skyecore | Jun 16, 2005 09:26pm | #5
    but use it or not, definatly buy it for 25cents per LF.
    ______________________________________________
    --> measure once / scribble several lines / spend some time figuring out wich scribble / cut the wrong line / get mad
  6. Piffin | Jun 17, 2005 12:27am | #6
    You definitely want to go square edge and take those tougues off
    1. johnharkins | Jun 17, 2005 01:50am | #7
      chime in here
      ebtys work fine on 3 / 4 material
      unless you have a roof over the deck and can keep a glistening look to that redwood it may be a pity to lay it down
      whatever you do w/ it you'll see 2nd growth or virgin VG redwood even at 1 X 6 is very strong, durable material
