2-3/8″ vent stack?
pjmcgarvey | Posted in General Discussion on September 14, 2007 11:29am
I need to connect to an existing vent stack that is 2-3/8″ in diameter, that I need to connect a pvc vent stack to.  Problem is, there are to my knowledge, no rubber couplings that have a 2-3/8″ Inside Diameter.
I’m thinking it would not be a good idea long-term to stretch a 2″ coupling to 2-3/8″, but would a 2-1/2″ coupling take up that 1/8″ of slack?  Open to other suggestions…
Thanks, PJ
    IMERC | Sep 14, 2007 11:40pm | #1
    if that is the OD (Outside Diameter) mearsurement it is a 2" pipe...
    pipe is read and called by the ID... (Inside Diameter)...
    if the stack is a galvinized or iron pipe - whatever sizw you are trying to hook up by 2" iron is what you are looking for...
    Fernco has what you need... plumbing supply houses everywhere...
    WOW!!! What a Ride!
    1. pjmcgarvey | Sep 14, 2007 11:46pm | #2
      wow, feeling kind of stupid now.  Thanks!
      PJ
        IMERC | Sep 14, 2007 11:51pm | #3
        most here won't see it that way...
        better to have asked...
        you should know that by now...
        Edited 9/14/2007 4:52 pm by IMERC
      2. Piffin | Sep 15, 2007 02:24am | #4
        Look at it this way - there is no better place to pull a boner than with a bunch of strangers on the web. You don't have to worry avbout running into us at the coffee shop, or that we can ever see your red face.We've all done it.
        Doctors, preachers, and life oaches all recomend it - a regular dose of humility keeps us, well, regular...Welcome to BT
      3. Shacko | Sep 15, 2007 07:07pm | #10
        The only stupid person is the one that won't ask questions! Lots of luck.
    2. caseyr | Sep 15, 2007 10:43pm | #11
      It is actually even a little more complicated. For 1" ANSI Schedule 40 steel pipe the actual internal dimension is specified as 1.05 inch while the external diameter is 1.32". For Schedule 80 steel pipe, the external diameter remains the same while the extra wall thickness reduces the internal diameter to 0.96". There are even heavier wall thicknesses of steel pipe that reduce the internal diameter even further. The Engineer's Tool Box has tables that give standard dimensions for ANSI Schedule 40 and Schedule 80 steel pipe at:http://www.engineeringtoolbox.com/ansi-steel-pipes-d_305.html
      http://www.engineeringtoolbox.com/ansi-steel-pipes-d_306.html
        IMERC | Sep 16, 2007 02:55am | #13
        I know this...
        and then we get into SCH120.....
        but for the OP and his residence figuring in SCH40 should do just fine.........
  2. DanH | Sep 15, 2007 04:40am | #5
    To make it even more confusing, 2" iron pipe is larger than 2" ID (or at least that's true with smaller pipes). The inch designation refers to the mythical pipe produced back around 1890, and the stuff used since maybe 1935 has a thinner wall and hence larger ID (to maintain the same OD, since that's where the threads are).
    Similarly, plastic pipe comes in several different wall thicknesses, with corresponding differences in ID.
      IMERC | Sep 15, 2007 06:56am | #6
      so much fer that bowl of Wheaties...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
      BillHartmann | Sep 15, 2007 07:05am | #7
      But to be even more confusing while pipe is designated by ID, tubing is designated by OD.Thus compression fittings for used with 5/8" copper tubbing is perfect fit for 1/2" copper pipe..
        Sphere | Sep 15, 2007 02:28pm | #8
        wait till they make metric pipe..lolSpheramid Enterprises Architectural Woodworks
        "If you want something you've never had, do something you've never done"
          BillHartmann | Sep 15, 2007 04:18pm | #9
          Years ago I heard something interesting about metric standards.They said that things like screws using metric screws where completely different from ASE standards.But other items, one mentioned was oil field pipe, was given metric numbers, but in fact was still the US standard dimenensions..
        2. rich1 | Sep 16, 2007 02:23am | #12
          Uhhhh they already do.
