(2) 360’ rotating lasers at a 90’ angle?
PonyMT | Posted in General Discussion on May 25, 2009 10:41am
Does anyone know if there’s a level manufacture that offers a level with (2) 360’ rotating lasers at a 90’ angle? I thought I remembered True Mark having one, but that was ten or more years ago. They work great for squaring step-down foundations.
  1. pell | May 26, 2009 02:43am | #1
    Try a pls 90 depending on accuracy needed.not a rotating level but shoots up slope and 90. I like mine but can be refered as p.o.s.
  2. plslaser | Aug 04, 2009 02:03am | #2
    PonyMT:
    Just reading a few comments on Breaktime. I don't normally contribute but you may consider the PLS 90 for squaring up and down stepped foundations.
    Does not give you a 360 vertical but it does give you a 90 with a good fan angle.
    See our video on http://www.plslaser.com
    Cheers,
    Mike
    PLS
  3. ruffmike | Aug 04, 2009 04:10am | #3
    I've never seen a laser with two spinners. Hilti's spinners shoot a fixed beam at 90 degrees off the spinning beam though.
                                Mike
        Small wheel turn by the fire and rod, big wheel turn by the grace of god.
    Matt | Aug 04, 2009 04:30am | #4
    The tool I use for foundatiion layouts is very simple to use and 99.9% accurate.  Costs $125 per use.  It's call a surveyor. ;-)
