How do you connect #2 AL to a main panel breaker? I am trying to save money on copper. Do I need a new box above the main panel to tie into?
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
Greetings b,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
-Thoreau's Walden
Generally you place the wire under the AL-rated clamp on the breaker and tighten. (Though the paranoid among us would apply some contact grease first.) Of course, you need to make sure that the breaker is AL rated.
#2 Aluminum seems a bit on the small side; don't forget that you need larger wires when you use aluminum in place of copper.
