2″ Carbide hole saw for porcelain tile?
hurnik | Posted in Tools for Home Building on April 13, 2008 11:55am
I need to drill a 2″ hole in the middle of porcelain tile.
I see that I can use basically two kinds of hole saws:
Carbide (but all the ones I find just say for ceramic tile)–not sure if it’ll work on porcelain?
diamond (much more expensive).
Anyone know if you can use the carbide ones on porcelain?
    IMERC | Apr 14, 2008 12:06am | #1
    get the porcelain cutter for yur rotozip and have at it...
    WOW!!! What a Ride!
  2. Pelipeth | Apr 14, 2008 03:38am | #2
    Because of convience I just stop by my granite guys shop and have him cut it for me with the wet diamond hole saw & give his man a couple of bucks. It's just a thought.
  3. sledgehammer | Apr 14, 2008 03:45am | #3
    Don't bother with carbide, you'll just break tiles. You need diamond tooling. Got a set of 5 hole saw bits from overstock.com  a couple of years ago for under 40 bucks and they are still going strong.
    1. wane | Apr 14, 2008 03:20pm | #4
      diamond and lots and lots and lots of water ...
  4. Shoeman | Apr 14, 2008 04:36pm | #5
    I recently had to drill a hole in a very hard porcelain tile.  Not having much luck with the tools I had - carbide.
    Went to a contractor's supply house for tile.  They reccommended the Perfect Hole saw by FlorCraft.  I used it, and it worked very well.  Would not work for tile already mounted on a vertical surface, but, if you are cutting on a new tile that has not been installed yet, it works well - makes a very clean hole.
    I was supprised to see that it used a hammer drill, but, like I say - it worked well.
    I have since seen them carried at Menards.  The 1 3/8" saw I needed ran around $25 if I remember right.
    Here is a link to this type of system on U tube -   http://www.youtube.com/watch?v=ZcS9RkoloKQ
    good luck
  5. cliffy | Apr 14, 2008 05:19pm | #6
    I just used the home depot holesaw for ceramic tile on porcelin tile a few weeks ago. It worked great. I didn't rush the cut and the holes were fine.  I had to run 3/4 copper through the floor for new hot water baseboards so I was a little worried about cracking the tile.
    Have a good day
    Cliffy
