2 inch setback on entry lock
doby | Posted in General Discussion on February 9, 2006 06:32am
I have an entry door about 25 years old. It has a key operated deadbolt along with a separate latch handle.The problem is the setback on the lock is 2 inches and I can’t find a replacement with this setback. I guess the tumblers inside are worn and I have to fool with the key a long time before the lock will open or close.Even a new key does not work. Does anyone have any  idea where I can get a lockset with this setback?l
  1. WayneL5 | Feb 10, 2006 04:47am | #1
    No, but a locksmith should be able to repair it.  That's what locksmiths do.
    1. doby | Feb 11, 2006 01:11am | #2
      I had it to a locksmith and he said it was not repairable.Too many parts are worn.
    aimless | Feb 11, 2006 08:17am | #3
    Did you ask the locksmith about available replacements?
    If you can't get a new lock to work in the old hole, then you might have to put a dutchman patch into the old hole and drill a new hole for the new lock set.
    1. pdennis | Feb 17, 2006 03:54am | #4
      When I was on the locksmith forum there was always a thread on this subject and almost all said this lock wasn't made anymore and there weren't any parts. Once in a while someone did say there was some obscure supplier. Mostly replacing the door was the answer if there wasn't room for a longer backset.
