2 wiring questions
GotAll10 | Posted in General Discussion on February 27, 2011 10:50am
1.  I am installing a light above a shower.  I plan to get the power from a GFCI outlet in the bathroom (20 amp circuit dedicated to bathroom), which is the last outlet on the circuit.  Can I use 14 gauge wire from the outlet to the light and switch since it will only carry current to one light bulb, or do I need to use 12 gauge wire since it is on a 20 amp circuit?
2.  I need to wire a 3-way switch.  Instead of using 14-3 cable between the switches (another $15), can I use one wire in a second 14-2 cable as the traveler (I have plenty extra)?
Thanks,
Paul
  1. DanH | Feb 28, 2011 06:37am | #1
    There may be some specific exemptions I'm not familiar with, but in general the answer is no to both questions.
  2. JTC1 | Feb 28, 2011 08:17am | #2
    Well, may depend....
    .....on your electrical inspector.
    1) #14 wire in a 20A protected circuit? - no, in anybody's book.
    2) 2 runs of 14-2 rather than 1 run 14-3?   This one will fly here with a couple of provisions:
    1st run of 14-2 gets installed normally; 2nd run of 14-2 gets the black wire recoded to red at both ends; white gets capped with a crimped-on closed end connector, ground gets twisted together with all the other grounds as per SOP.
    The inspector told us that many overhead light installations, in bedrooms most frequently, are roughed-in with a fan rated ceiling box and 14-3 cable to allow installation of a ceiling fan w/ light. Then instead of a fan / light a standard light fixture is installed.   The unused red conductor is crimp-on capped and coiled in both boxes for possible future fan installation.
    He failed to see the difference between to two installations; both have an extra conductor present in the boxes and a connected ground present in all cable sheathes. Not the neatest installation but acceptable.
    Bottom line - check with your inspector on #2.
    Jim
    1. DanH | Feb 28, 2011 08:17pm | #3
      There are ways to interpret the code as requiring all wires of a circuit to run within a single sheath.  But there are all sorts of qualifications on that rule.
  3. gfretwell | Feb 28, 2011 08:33pm | #4
    No and no.
Mortar for Old Masonry
