26″ Slab Door – An oddball size?
TIM_PH | Posted in General Discussion on March 11, 2013 09:58am
In the process of finishing up the interior door project of my house.
The last one is the basement door, which has a 26″ wide slab. Can’t find any in stock at any lumber yard or box store, So I’m guessing this is an oddball size.
Is this size available or do I need to increase the rough opening to accomodate the 28″ wide slab?
If it means anything, the house was built in ’78. Perhaps 26″ slabs were a trend during that time era?
thnx in advance for the consult~
  1. calvin | Mar 11, 2013 10:36pm | #1
    Tim
    Can't say I remember ever framing for, hanging or needing to find, a 2'-2" door, so I googled............
    of course, typing in  2'-2" door was the wrong way.
    Tried 26 inch door and this came up:
    http://www.discountmobilehomeparts.com/cgi-bin/shop/pid_650.htm
  2. oops | Mar 11, 2013 10:53pm | #2
    door
    It is not one of the more common sizes but it is not all that unique.  It is not likely to be a stock item.  Your real lumber yard should not have any problem ordering  one for you.  I spec them every once in a while if needed for a special  case.
  3. DanH | Mar 12, 2013 07:06am | #3
    If you get a slab with thick edges it should be possible to trim a 28" down.  (Of course, the thick-edged slab is likely an expensive special-order item.)  Worst case you can just rip down a standard hollow-core (take it all off of one edge) and then re-glue the edge.
    Or, of course, get a solid slab.  But the weight of those (not to mention the expense) is a significant issue.
  4. rredogg | Mar 12, 2013 09:04pm | #4
    Your door
    I know your not looking for a pre-hung door but when doing my doors which were pre-hung I went to one of the big box stores and found out the 26" ers were a "special order."  About double to price of a standard sized door.
Picture-Perfect Pergola
