3/4″ ply enough for tile floor?
Biff_Loman | Posted in Construction Techniques on November 21, 2007 10:46am
I have an exterior door that opens to a landing halfway up a flight of stairs. The landing’s floor is currently 3/4″ ply under 1/4″ underlay, on top of which is vinyl tile.
The vinyl tile doesn’t suit me one bit. But the door’s sweep already drags across the floor. If I increase the depth, I’d have to cut down my door, and I’m not sure I care to do that.
Do you figure I could get away with laying ceramic directly on the 3/4″ subfloor?
Edited 11/21/2007 2:47 pm ET by Biff_Loman
  1. joeh | Nov 21, 2007 11:22pm | #1
    Do you figure I could get away with laying ceramic directly on the 3/4" subfloor?
    The winning answer is "maybe".
    What's under the ply? How big is the landing?
    The problem is deflection, with a stair landing it is probably a small area so less span = less deflection.
    Can you see what's under it and maybe beef it up if needed?
    More info required.
    Joe H
    1. Biff_Loman | Nov 21, 2007 11:29pm | #2
      Landing is 3' x 4', supported by 2x6s on 16" centers. Sistering them to reduce deflection is absolutely not a problem. I have no idea if that's necessary though.
      1. joeh | Nov 22, 2007 12:37am | #3
        For the small price of a few 4' 2x6s you can be safe rather than sorry.
        I would run them between the existing joists so you have 8" centers.
        Joe H
    EricPaulson | Nov 22, 2007 02:07am | #4
    Kerdi Ditra first.
    [email protected]
    1. Biff_Loman | Nov 22, 2007 02:37am | #5
      Hey, good thinking. I should see if I can grab an off-cut from the local tile place. I'm on good terms with them.
        EricPaulson | Nov 22, 2007 02:46am | #6
        Schluter Kerdi is waht I meant.[email protected]
      2. pinko | Nov 22, 2007 02:54am | #7
        2x6's @ 16"o.c. for a 3' or 4' span is WAY plenty of support under the 3/4 ply. No worries on deflection; you'd be wasting your time sistering..OTOH, Ditra is cheap insurance if you can get a small piece.. BTW, for all who are interested, HD now sells Ditra in small quantities, as well as other schluter products. I suspect Kerdi isn't far behind..If you can't get the Ditra, just use a good modified thinset, stick 'em down to the plywood and fuggetuboutit.ALSO btw, TEC has a new de-coupling thinset that's supposed to restrain up to 1/8" cracks...here: http://www.tecspecialty.com/product_detail.asp?prodId=133From the site: "..IsoLight is a lightweight, 1/8" crack isolation mortar that protects tile from substrate cracking and exceeds ANSI A118.4 and ANSI A118.11 shear bond specifications."I'd probably use it for situations like yours.
        1. Biff_Loman | Nov 22, 2007 04:14am | #8
          This is great stuff, guys. God I love this forum.That might very well be tomorrow's project. This whole unemployment thing isn't so bad, as long as you already have all the materials out in the shed. :P
        EricPaulson | Nov 22, 2007 06:28am | #9
        Ditra is actually what I meant. trying to catch up..............[email protected]
        1. Biff_Loman | Nov 22, 2007 06:53am | #10
          Waaaaa???? Head explodes. . . !!!Nah, just kidding. Kerdi is for showers, Ditra is for floors; looks kinda like orange delta. Like I said, I love this forum!
  3. JohnW1111 | Nov 25, 2007 01:53am | #11
    Bill
    The issue is not the 3/4 ply its a question of how secure and tight the existing floor is.
    If you have alot of give or the floor sags thats a problem.  Ceramic tile is typically not all that heavy.  3/4 inch ply is a good subfloor as long as its solid and level.
    John
Fast, Accurate Wall Framing
