3/4″ Water Regulator Question
RobKress | Posted in Energy, Heating & Insulation on August 2, 2004 01:57am
Hi all,
Quick plumbing question here…..
I installed a 3/4″ watts water reducing valve at the water inlet to my house.  The whole house has been plumbed with 3/4″ copper with short branches done in 1/2″.  My problem is that there seems to be not really enough flow anywhere in the house (which is not completely done but the water system is up and running).  I get great pressure (I can set up to 75 psi) and that doesn’t seem to be the problem.  But when I am running my outside hoses or the utility sink in the basement, there just doesn’t seem to be enough water coming out.
Is my regulator too small?  Is a 3/4″ watts typical install for new construction? (I got it at Lowes but have access to any other regulator that would do me better).  Can I install a 1″ or will the valve in the regulator chatter?  Is there a high flow version of a 3/4″?  Am I barking up the wrong tree?
Thanks for any help guys,
Rob Kress
  1. davidmeiland | Aug 02, 2004 02:06am | #1
    I assume you mean pressure reducer.... to bring the town water main pressure down to the +/- 80 PSI you want in your house lines?
    BillHartmann | Aug 02, 2004 03:22am | #2
    What does the pressure read when you have water flowing?
      Sphere | Aug 02, 2004 03:49am | #3
      A Zane Gray novel?
      sorry..couldn't help it.
        RobKress | Aug 02, 2004 04:30am | #4
        Who the hell is Zane Gray?
        No, for the other guys, I have not read a pressure guage while running water but I bet that would be telling.  And yes, I am talking about my pressure reducing valve on the inlet water supply to my house from the city source.
        Thanks for inquiring further,
        Rob Kress
  3. sungod | Aug 02, 2004 04:53am | #5
    Is the arrow on the regulator pointing in the right direction?
      RobKress | Aug 02, 2004 06:53am | #6
      It won't work any othe way, so of course.
      Rob Kress
