3 gallon compressor – won’t go to 75+ psi?
netrate | Posted in Construction Techniques on July 16, 2013 06:29am
Each time I run my Campbell Hausfeld compressor (rated for 100PSI), the release value lets out the air at about 75 psi and I am not sure what the reason is. I have taken out the release valve to look at it, but I think it is fine. The spring seems good. I am not sure if maybe I should spray some silicone spray into it to make sure it has a full range of motion. any ideas? The compressor is old so there is no returning it (my dad’s)
    MarkH | Jul 16, 2013 06:35pm | #1
    I guess the popoff valve is bad.  Can you hold it in and get to full pressure?  I have one of those, that shuts off at 125 psi, but it wont ever get there anymore.  Tops off about 120 psior so  and wont ever shut off.  I think the cylinder or valves? have worn out.
    1. netrate | Jul 16, 2013 06:53pm | #2
      How do you fix one? I have put pressure on it and it seems to stay put, but as soon as I let go...
      Can you get replacements for those?
      1. DanH | Jul 16, 2013 08:55pm | #3
        https://www.google.com/#output=search&sclient=psy-ab&q=125+psi+pop+off+valve&oq=125+psi+pop&gs_l=hp.1.0.0i22i30l2.1456.5774.0.8064.13.11.1.1.1.0.215.1176.6j4j1.11.0....0...1c.1.21.psy-ab.Gj47Z1tBlcc&pbx=1&bav=on.2,or.r_qf.&bvm=bv.49405654,d.aWc&fp=1af81ef7fdf7d538&biw=1105&bih=583
        MarkH | Jul 17, 2013 06:34am | #4
        Yes, you can get replacements for those.  If you are in an industrial area they should be available locally.  Also they should be at stores like tractor supply.  Should be a  pretty inexpensive part.  Always available online too.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
