3 things a plumber’s gotta know?
| Posted in General Discussion on March 9, 2003 06:03am
All,
        After reading the “I think I breathed something bad” thread and reading Luka’s post, “Dood your dead” , Something I’ve heard plumber’s often say came to mind.  What are the three CRITICAL things a plumber has to know?
1. payday is on Friday
2. $hit don’t run up hill.
3. Above all, DON’T BITE YOUR FINGERNAILS
                                                   Mark
  1. DaveRicheson | Mar 09, 2003 06:16am | #1
    4. Cold is on the right.
    1. kennedy136 | Mar 09, 2003 06:20am | #2
      Dave,
                Can't argue with that.
        coonass | Mar 09, 2003 06:46am | #3
        Gotta have some green glasses so the turds look like pickles.
        1. kennedy136 | Mar 09, 2003 04:03pm | #14
          Kearn,
                 I've heard it said, "Watch out for Lincoln logs and land mines"
    Luka | Mar 09, 2003 07:00am | #4
    Wheres the donuts.
    Wheres the check.
    Wheres the door.
    Quittin' Time
    1. DougU | Mar 09, 2003 07:12am | #5
      The plumber I know says the three things are....
      - sh!t flows downhill
      - paydays Friday
      - the boss is an a$$ hole
    2. kennedy136 | Mar 09, 2003 04:04pm | #15
      Luka,
              I'll go along with that.
        Luka | Mar 09, 2003 11:48pm | #22
        Whats not to agree with ?
        It's the same three things needed to be known by every working man... Framers, electricians, trim guys, painters, carpet layers, roofers, counter workers at Krispy Kreme, even computer technicians.
        Quittin' Time
        1. kennedy136 | Mar 10, 2003 12:41am | #23
          Luka,
                 Gotta draw the line there dude.  Some bosses are jerks yes.  But I don't believe for a minute that most are.  That's just hokey. REmember many if not most of the pros on this forum are bosses and I don't think you would honestly think that that automatically makes them a jerk.  However if you really do hold that view then it makes you guilty of the same bigotry and stereotyping that you resent with others  and have often said so.  As I said I don't think you really believe that but it comes across that way.
                                                             Mark
            Luka | Mar 10, 2003 01:28am | #25
            HUH ???
            Bosses ? Jerks ?
            Huh ???
            Quittin' Time
  3. CAGIV | Mar 09, 2003 08:24am | #6
    Don't forget plumbers are allowed to hack, cut, remove, destroy any piece of framing they see fit in order to install their lines.
     At least that's how our plumbers operate
    View ImageGo Jayhawks
    1. rez | Mar 09, 2003 08:30am | #7
      Ya but it's all the archy's fault for putting a 2x4 plumbers wall in the plans.
      1. CAGIV | Mar 09, 2003 08:52am | #8
        I think the main problem at least in remodeling is that the contractor and his subs do not get together to come up with an effective plan often enough
        I think a lot of problems could be avoided if, once the plan for a remodel was done.  All pertinent subs and the GC came together to look at the plans, each sub could give his 2 cents as to what he needs where, and any special prep work before he showed up.  Then when the plumber or HVAC guy showed up it would be less likely a stud was in the way etc.
        1. rez | Mar 09, 2003 08:56am | #9
          Oh ya, communication is where it's at for sure. But how often do you see that happen.
          Sometimes I marvel at how things get built.
          1. alias | Mar 09, 2003 09:17am | #10
            and all work is under the tail light warranty umbrella package...
          2. rez | Mar 09, 2003 02:15pm | #11
            Have gun will travel
          3. alias | Mar 09, 2003 03:15pm | #12
            no soap pass the radio?????
          4. rez | Mar 09, 2003 03:52pm | #13
            take your choice: listen to pms or npr. what's it going to be?
          5. alias | Mar 09, 2003 05:17pm | #17
            well at home here p.m.s. is a staple .####little socialist radio (n.p.r.) will be a relief. alittle "fresh air" and the morning news. yep that will do it.. keep the soap on hand tho.....
          6. andybuildz | Mar 09, 2003 06:13pm | #18
            bear
                 now that I'm doing all this plumbing here I finally understand what "no soap radio means"..heard that as a teen but now I'm a member.....cept when WFUV is runnin' RPN...then you can keep the soap and my fingers are covered in flux and blisters...maybe I should wear gloves when I wipe the solder clean....ahhhhh let it run down the pipes....cant hurt anything can it? Looks like a Decooning of pipe work
            Be a peace pipe being passd in a tipi ( those are lodge poles?.....oops...wrong plumbing gig)
                              Namaste
                                      your pal andy"As long as you have certain desires about how it ought to be you can't see how it is."  http://CLIFFORDRENOVATIONS.COM
          7. alias | Mar 09, 2003 06:58pm | #19
            just keep a rag handy give it a swipe w/ the rag 3 seconds after the sweat.... b
            Edited 3/9/2003 12:00:42 PM ET by the bear
          8. Piffin | Mar 09, 2003 07:54pm | #20
            communications
            Is that like when I told a plumber, "do NOT cut this diagonal brace out of this wall"
            and the first thing he cut when he pluggin the sawsall was________
            you guessed it!
            That's OK, I took a sledgehammer to his bill.
            His ears were clean next time i talked.
    2. kennedy136 | Mar 09, 2003 04:07pm | #16
      Cag,
             With some of them that seems to be the way it is.  On a serious note the inspectors in my area refuse to do a framing inspection until all the mechanicals are in.  Many a good framing job has been ruined by someone cutting something they shouldn't.
                                               Mark
  4. jayzog | Mar 09, 2003 11:30pm | #21
    My plumbers great!
    His line is " One mans sh!t, is another mans bread and butter"
    1. kennedy136 | Mar 10, 2003 12:45am | #24
      Jay,
            "MY plumber's great."
      So is mine but it sure took a while to find him, his predecessor was a butcher from the word go.  Guy before that did nice work but took forever.  To his credit he was in his early 70's and worked by himself, but I think his biggest failing was trying to work out of the back of an open pickup.  Just couldn't carry enough tools or material to be efficient.  Nice guy though.
                                      Mark
      1. Sancho | Mar 10, 2003 01:30am | #26
        I think we are forgetting Plumber clothing fashions..Pants with out belt loops so ya can see their crack...T shirts that allow plumbers to wipe there on hands on the Ts with a colorful slogan such as" gass, grass or a## no one rides for free."
        Darkworks:  We support the US military "We kick your #### and take your gas"
        VtMike | Mar 10, 2003 04:14am | #27
        I've been doing plumbing for twenty six years and now do just service. Most of my work would not be necessary if it was done right the first time.
        Yesterday I couldn't even spell plumber, today I are one.
        1. alias | Mar 10, 2003 04:55am | #28
          i've told my wife time and time again that if i had to doit again i'd spend 5 years with a master plumber. there gold' in dem dare pipes.....bear
          1. pm22 | Mar 10, 2003 05:31am | #29
            My three rules of plumbing are --
            1]  No matter how hard you tighten the pipes, when you turn on the water main, they will leak.
            2]  No matter how hard you try to loosen the pipes, the will be rusted solid.
            3]  The clog is always one foot further than the length of your snake.
            ~Peter
            Why do weathermen always lie about the weather?
