I spoke to a Pella salesman today who said that 34″ is not a standard entry door size. In Canada where I live, 34″ entry doors are very common.
Are 34″ entry doors in the States non-standard? Or is this salesman wrong?
Just curious.
Just curious.
Choosing the right heating and cooling system means finding the best fit for your home's size, layout, and climate—and balancing trade-offs in efficiency, comfort, and cost.
Maybe 34" is not standard for pella. My front door is 34"
Whenever you are asked if you can do a job, tell'em "Certainly, I can!" Then get busy and find out how to do it. T. Roosevelt
''In the states'' a 34'' entry door (at least around my neck of the woods in NJ) is not a common size.
3'0'' x 6'8'' on newer homes and 3'0'' x 7'0'' on the older.
___________________________________________
Common sense is a gift from God that cannot be taught.
I've worked on quit a few houses that were built around the turn of the last century and in one particular neighborhood I think all of the entry doors were 34". I don't think I have seen any done recently, not saying that they aren't done.
e2... 3/0 x 6/8 is a standard entry door... another size MOST door mfr's make is
2/8 x 6/8...
but 2/10 is very hard to come by in an exterior door
I sold at retail, doors manufactured by "window & door companies" with the modern extruded or vinyl coatings....all provided 3/0 and 2/8 units as a standard. Pella, Hurd, Andersen, Caradco.
Metal door manufacturers were about the same with some hard to find exceptions of 2/6 and 2/10, which usually had an extended ordering lead time.
Several local distributors/door unit assemblers would make-up wooden slab/wooden framed door units, exterior or interior with a spec of 2/10. Sometimes as a stock item, sometimes as a special order.
Not seen in todays building specs...mostly for remodels of older homes....50+ years or more. Most current specs (code suggestions) call for at least one entry, usually the front, to be of a minimum size of 36".
................Iron Helix
I thought code was 3/0 for at least one door in the house?
Maybe I dreamt that up somewhere..
I KNOW for handicap access, it is.
OK. Sounds like 34" is maybe not so much of a Canadian thing than an old standard. New construction here is 36" too I think. In older homes though, many are 34".
Thanks sphere and everyone else.
yes... notice i said entry door is 3/0... secondary doors ( exterior ) can be 2/8Mike Smith Rhode Island : Design / Build / Repair / Restore
While we're on the subject, is an exterior secondary door necessary? My client decided not to. Got a CO with just one door. Surprised me. Not so sure about resale, but the appraisal came in great. PAHS Designer/Builder- Bury it!
>> ... is an exterior secondary door necessary?
You mean for fire safety? I've never lived in a house without a back door, but I have lived in apartments and stayed in hotel rooms without one. Some have had egress windows, but some (11th floor at the Hyatt?) haven't.
"You mean for fire safety? I've never lived in a house without a back door, but I have lived in apartments and stayed in hotel rooms without one. Some have had egress windows, but some (11th floor at the Hyatt?) haven't."
Yes, but they did have alternate means to provide (hopefully) similar safety.
Smoke alarms monitored by ON SITE personal, fire isolation construction, and sprinker systems.
Looking at the 2000 IRC 1&2 family code they require ONE exit door that does direct acess wihout going through a garage.
And also emergency exits (which can be windows) in each sleeping room and also habital basements.
Regarding code requirements, I've learned it's best not to ask why. At least not from our building inspectors. One of the great benefits from this forum is that ability.
Bedroom egress was required. This is the only house I know of with only one exterior door.PAHS Designer/Builder- Bury it!
Here in Los Angeles, code minimum is 36" for the front door, and 32" for interior doors that people walk thru. Closet doors can be smaller. They have that on the plan checker's checklist.
-- J.S.
Common, but not "standard", you'll find a lot of 32" doors out there too.
Phill Giles
The Unionville Woodwright
Unionville, Ontario
Have you tried Lowen (sp?) ? Not sure if they have entry doors, but they're from Canada and what they do make is a good product.
MES
What surprised me was interior doors. 32, 30, 28, and 24" are common, but not 26".
I was cutting through a wall for a bathroom door in a basement, I was limited on one side by the furnace and wanted a closet on the other side.
26" would have been an easy fit and I would have used it if available. By leaving an support beam in the back of the closet partiall uncoverd by the DW and framing the closet with 1 5/8" steel walls I was able to be the 28" door in.
Every thing I have seen in Tx. is 3-0 in front and 2-8 inthe rear doors (on homes at least 30years old),Now they are all 3-0 on residences...
Scribe once, cut once!(David Banes)
34" doors are the least common here in Minnesota - 36" being the most common.
however 34s are not that hard to come by as a special order, and some of the Home Depots and Menards here stock 34" steel exterior doors by Stanley and Mastercraft.
2/10 for the front door. It's a Canadian thing, eh?
Maybe our northern cousins don't do as many supersized lunches as we do?
My Loewen is a 32". That came a standard with the two sidelight package.
