4′ x 32′ subflooring?
Brian | Posted in General Discussion on May 4, 2006 06:55am
My town is a hub for building materials – at the intersection of two major interstates – distribution centers everywhere…anyway on a truck the other day…
I thought I saw osb subflooring in really long sheets.
Since I joists are manufactured and can be as long as you want (if truckable) why couldn’t sheathing, subfloor etc?
Only builders with forklifts could handle them, but would there be any sense in it?
Can you imagine lining up the t&g on a 4′ x 32′ piece of advantech?
Time savings, stronger floors…
Is there such an animal, and is it a pita, or a time saver?
Treat every person you meet like you will know them the rest of your life – you just might!
  1. woodroe | May 04, 2006 07:08am | #1
    Sounds like it could work, but what about expansion. That old 3/4" sub floor was spaced because if it wasn't and got rained on, it expanded and blew the top course of block off the foundation.
    BillHartmann | May 04, 2006 07:13am | #2
    I think that there is. But probably not sold for subflooring.
    I think that they are used for i-joist and the like.
    On some of the home improvement TV shows from time to time they show plans that make those kind of products.
    And many of them are made in long sheets and cut on the fly.
    gdcarpenter | May 04, 2006 08:08am | #3
    I think them there manufactured housing construction folks probably get 'em in long sheets.
    Let's not confuse the issue with facts!
    1. Brian | May 06, 2006 09:51pm | #4
      Yeah, it could be for the modular builders - there are a few locally.  I'd never want to carry one from the pile.  I might be able to make a case for 2' x 32' subflooring, though.
       Treat every person you meet like you will know them the rest of your life - you just might!
    LEMONJELLO | May 06, 2006 11:10pm | #5
    SIP mfg. uses em.
    Make a big oreo cookie with foam then cut to size.
    SIP's can come 10 ft wide in some cases. So you need larger panels with no seams
  5. JonE | May 06, 2006 11:24pm | #6
    Used for structural insulated panels.   Also could be stock for the center of TJI's.
A New Approach to Foundations
