40 Gal. Gas hot water heater
jimmyoz | Posted in Energy, Heating & Insulation on July 11, 2007 01:42am
My 40 gal. gas fired hot water heater is 12 years old and I think it’s time to replace.
Does any one have a good reliable brand to recommend?
I know I have a Bradford White and it lasted these 12 years, but is this the best?
Can any one make a a recommendation??
  1. IronHelix | Jul 11, 2007 02:24am | #1
    Probably a number of name-brand sources...many the same as 12 years ago!
    BUT.... your big shock will be the price tag!    Double...plus!
    All the manufacturer's sleep together so pricing is close...differences depend on the mark-up at retail/wholesale.
    If you got 12 years out of a B/W.....don't be afraid to repeat!   Although 20 would have been better!  Lots of variables effect longevity.
    ...............Iron Helix
    1. DanH | Jul 11, 2007 02:28am | #2
      Our 52 gallon State electric is nearly 31 years old.
      Edited 7/10/2007 7:31 pm by DanH
      BillHartmann | Jul 11, 2007 02:35am | #3
      You can blame the government for part of that increase.They think that anybody should be able to take a bath using gas next the water heater and not blow up..
      1. rich1 | Jul 11, 2007 06:02am | #8
        The manufacturers went to the governments of  the US and Canada and asked for the regs to be enacted.
        Liability was a BIG issue.
    3. jimmyoz | Jul 11, 2007 04:56pm | #10
      Thanks guys for all the info. I appreciate it very much
    rjw | Jul 11, 2007 03:03am | #4
    Keep in mind that scale build-up reduces efficiency - 1/2" scale increases energy costs 70% (Family of 4, todays gas price's, 1 year ~$250!)
    In my area I'm told 1/10" a year is normal scale buildup.
    For the past several years, water heaters have been required to have anti-flash-back devices so if volatile gas reach the flame, the flame won't spread to te source nd possibly explode.
    (We lost a guy in Toledo last year to such an explosion)
    With my mouth I will give great thanks to the Lord; I will praise Him in the midst of the throng. For He stands at the right hand of the needy, to save them from those who would condemn them to death.
    - Psalms 109:30-31
    1. frenchy | Jul 11, 2007 04:06am | #5
      rjw,
        You're right scale buildup is a local issue.. My 20 year old water heater had zero build up.
       In fact I found zero, no build up in any of my plumbing as I took it apart.. since it was in such nice shape I simply reused much of it..
    2. BillHoover | Jul 11, 2007 09:44pm | #12
      RJW,
      I beg to differ with your scale and costs numbers.  Since 80% of the heat enters the water from the flue and not the bottom of the heater, there is no way that .50" of scale in the bottom will increase the energy costs as much as you stated.  In reality, energy costs will go up with age but not dramatically.
      While the new heater will look like the old, there are a number of significant differences...all mandated by the government...that have raised the costs.  the new units are significantly more energy efficient, they use environmentally friendly foam insulation and they are flammable vapor ignition resistant.  All of these features coupled with large prices increases for steel have caused the large price increase of the water heaters.
      Bill
        rjw | Jul 12, 2007 01:55am | #14
        >>I beg to differ with your scale and costs numbers.Well, that was a figure at one of the manufacturer's sites.>>Since 80% of the heat enters the water from the flue and not the bottom of the heater,I hadn't run across that figure before.As a general rule, it has been my experience that the older the unit, the higher the flue gas temps at the top of the flue (having tested several hundred.)I've always attributed that to scale buildup, but maybe not?
        - Psalms 109:30-31
  3. WayneL5 | Jul 11, 2007 04:25am | #6
    Consumer Reports rated water heaters sometime last year, I think.  Their conclusion was that all the brands did equally well, that the best indicator of quality was price.  In other words, in any manufacturer's line, going up to higher priced units did in fact by quality.  The brand itself did not really matter.
  4. grpphoto | Jul 11, 2007 05:09am | #7
    The problem with that is, by the time a brand becomes reliable, you only know that the stuff they built 15 years or so back was pretty good. You will never know if their current product is reliable.
    I just bought a GE. They bought out Rheem, so I believe mine will last.
    If you intend to stay in the house at least 8 years, you also might consider the tankless variety. Bosch makes an excellent one that runs about $1,000. There's a sizable tax credit on them to cut the cost down, and the operating cost is a lot cheaper than the regular ones.
    George Patterson
      BillHartmann | Jul 11, 2007 06:43am | #9
      "I just bought a GE. They bought out Rheem,"What makes you say that. Rheem is privately held accordign to their PR and GE does not claim them..
    2. jimmyoz | Jul 11, 2007 05:22pm | #11
      Thanks for the insight , George.
      Is Rannui familar to you?
      I see them advertised pretty much in the tankless realm
    3. BillHoover | Jul 11, 2007 09:46pm | #13
      One small correction GE did not by Rheem.  In fact, Rheem makes the GE heaters for Home Depot.
      Bill
Two Ways to Test Windows
  • The New Old Colonial
