4ft to base of footing or wall?
davewick | Posted in Construction Techniques on September 26, 2006 04:51am
Newbie question here:
If my local codes in massachusettes say that the wall must extend to more than 4 feet below frost line, does that mean the footing only needs to be deeper than 4 feet, or does the base of the poured wall need to be lower than 4 feet? IE for a 10″ thick footing I’d have to dig 4′-10″ to be up to code? This doesn’t make sense, but it’s what the guys in the office claim….
-D
    G80104 | Sep 26, 2006 05:06am | #1
     We would keep in mind that you have about 8" of foundation above ground per code. So if soil conditions are right, you could do an 8" footing with a 48" wall above & you would have 48" below grade to meet frost requirements.
     Around here we follow the 2003 IRC code book, its a  good investment & an EZ read & only cost $42.00
      With your 4'10" you should have an extra 2" to spare. Hope it all works out 4-U!
  2. BoJangles | Sep 26, 2006 05:12am | #2
    "If my local codes in massachusettes say that the wall must extend to more than 4 feet below frost line"
    I doubt that it actually says that??  :)
    I'm sure what they mean is that the bottom of the footing must be 4 feet below ground level, to be "below the frost line".  The bottom of the wall itself has nothing to do with it.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
