4×10 plywood?
stevieraycharles | Posted in General Discussion on March 29, 2005 03:14am
I was working on a 1950’s ranch house recently that had 4×9 3/8 fir plywood on carport walls. I am in need of a lightweight ceiling material to suspend from the bottom chords of w-trusses in my shop (10′ o.c.) I thought 4×8 was all that was made in plywood. Has anyone seen 4×10 plywood before?
  1. davidmeiland | Mar 29, 2005 03:35am | #1
    Get ahold of a decent plywood distributor and you'll be surprised at what you can get. 4x10... definitely.
    Here's a place I used to go:
    http://www.truittandwhite.com/products/index.cfm?fuseaction=plywood
    1. Lansdown | Mar 29, 2005 03:59am | #2
      Here is another source Roberts Plywood on Long Island, NY. http://www.getwood.com/
    MarkH | Mar 29, 2005 05:30am | #3
    I dont think you can just order a few sheets, and 10' would sag down anyway. Maybe you could fur it with some flat 2x, then put up something readily available. I would probably use drywall myself, but you could use big ceiling tiles.
  3. RTC | Mar 29, 2005 05:35am | #4
    i just got done with a job where we sheathed with 4'by 9' 1" OSB.
    RTC
      Timuhler | Mar 29, 2005 06:31am | #5
      How heavy were those sheets?!
      Our next job is 9' walls (and 10 and 11 and 14 :-)) and we'll use a lot of 4x10 OSB, but that is 7/16"  I can't imagine 1"!!
      1. RTC | Mar 29, 2005 08:38am | #7
        i didn't mean that it was 1" thick, i meant that it was 9'1" in length.yeah 1" thick would be a nightmare for sheathing.sorry bout the confusion.
        RTC
          Timuhler | Mar 29, 2005 03:33pm | #8
          I was thinking you are Hercules :-)
          1. MisterT | Mar 30, 2005 02:25am | #9
            If you turned off the cut-off saw at the OSB plant, you could make a 4x1mile sheet!!
            just need a heck of a delivery truck is all!
            MrT, SamT, DanT,RonT,Ms.T…<!----><!---->
            Whatever…<!---->
            Welcome to Breaktime!!!<!---->
            Where…<!---->
            The free advice is worth every Penny!!!<!---->
            :P<!---->
  4. blue_eyed_devil | Mar 29, 2005 07:24am | #6
    Brushwacker, 4' x10' x 3/8" exterior plywood is a normal stock item here in Michigan in builder yards. It comes in smooth fir and rough sawn fir. We can get 10' stock for all sidings too such as T-111 and OSB products.
    blue
    Just because you can, doesn't mean you should!
    Warning! Be cautious when taking any framing advice from me. There are some in here who think I'm a hackmeister...they might be right! Of course, they might be wrong too!
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
