5 1/2″ maple t&g flooring–face screw?
Megunticook | Posted in Construction Techniques on March 21, 2003 04:24am
Hi,
Searched the archives on plank flooring and wasn’t able to find a definitive answer to this.
I’m in the process of installing some 5-1/2 x 3/4″ t&g maple flooring from a local mill (some is end-matched, but not all). Just finished one room, blind nailed with 2″ cleats over 3/4″ Advantech and joists. Nailed about every 8″. Joists are 24″ o.c.
Was planning to countersink screws into the faces. Is this recommended? What spacing?
My concern would be to allow for the wood’s seasonal movement. There is 1/2″ expansion space around the perimeter. Wood was brought into the “target” rooms very soon after milling and stored for six weeks. All subflooring is dry, house is weathertight and rooms are kept at fairly consistent temperature and humidity.
Seems two face screws at every joist would be a good idea, but I’ve been reading conflicting notions on this. Any opinions would be appreciated.
Thanks,
Ed
  1. migraine | Mar 21, 2003 05:08am | #1
    Do you really want it to look a boat deck? Imagine having to plug and chisel everything.   Try blind nailing with a flooring nailer instead
  2. Piffin | Mar 21, 2003 05:20am | #2
    I would expect that to cause a lot of splitting and checking at the screws. If you have to do it for appearance or something, I would make the countersink hole oversized.
  3. villagehandyman | Mar 21, 2003 05:26am | #3
    all those screws will look terrible ifyou are worried about warping and cupping seal the bottom side and end grain before laying the floor i recommend a good polyurethane seal it real heavy and let it dry then lay the floor blind nail maybe use some construction adhesive if it is a big room and then sand and finish the top surface  do not apply top coat to thick two coats maybe three and the floor will not mar as easy
  4. Floorman | Mar 21, 2003 06:06am | #4
    You have done everything necessary in the installation. The only reason that one would use a screwing process is if you were to add walnut plugs on the ends of the boards. With wide plank (7"+), screws would be added under the plugs as an extra binder. I do not use screws even under plugs with 7" wide oak.  I install in the beach cities of South Orange County in So. Cal. and North San Diego County. In other words, we get a fair amount of moisture and I have no problems without screws. I'm a 25 year flooring veteran. As a note, many installers are using urethane glue full spread under any plank 5" and wider. I only use glue under 7+ widths and greater, like wide Pine, Hickory and walnut. GW
    Edited 3/20/2003 11:08:11 PM ET by Greg Warren
    Edited 3/20/2003 11:11:35 PM ET by Greg Warren
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
