I cant explain why a 6/12 is 26.56 roughly and a 12/12 is 45 other than it just is,that it is not a straight line progression.Could someone tell me and my crew why a 6/12 is not half of a 12/12 Thanks in advance
confused by the paradox……..or is it magic? Pell
Pell,
It is because of the way the 6/12 and 12/12 is measured. Angles are based on a circle which is 360 degrees. If you draw it on paper you will see what I mean. If you start at a point, a line drawn at 6/12 pitch will be more than half of that drawn at a 12/12 pitch. Kind of hard to describe without drawing it. Maybe I will see if I can make a drawing and scan it in ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Picture a circle with a 12" radius. A line drawn from the center horizontally to one edge, 12" long, represents 0°. Vertically, the line represents 90°. Halfway between is 45°.
Now picture a 12" x 12" square. The base of the square is 0°. Draw a line from a bottom corner, halfway up the other side. That line is a 6/12 pitch. Draw a line from the bottom corner to the diagonally opposite corner. That line is a 12/12 pitch.
Note that in the circle, the line stays the same length. In the square, the length of the line changes.
If the line within the square did not change length, but rotated from 0° to a line cutting across the center of the square, it WOULD be 45°. Instead, because its length increases, the angle is effectively reduced.
The short answer is because circles ain't square.
Pi are square."Put your creed in your deed." Emerson
Pie's are round in my world.
>>Pi are square.<<
No, NO, No, No,........
How many times does this have to be splained ----
pi are round
cake are square!
JimNever underestimate the value of a sharp pencil or good light.
Sooooooooooooo.....................why are manhole covers round?
Because the manholes are round, silly.
As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
Because round covers can't fall through the hole and rectilinear ones can.
Depends on the shape of the hole, doesn't it?
Can you make a rectilinear shape that cannot fall through it's own "hole"?The only way I can see that being true is if you have a lid that is thicker than the shape in the short dimension.
Just gotta make the lid sufficiently larger than the hole.
Oh, I assumed you were being practical.
Make the lid smaller than the hole and even a round cover will fall through.
A lid smaller than the hole isn't a lid.
Depends on what the lid is comprised of.
2 Pi r squared
1 pie are food
2 Pi are area
squared
hopefully, this diagram will show that even 'tho numerically 6 is half of 12, a 6:12 roof pitch is not truly half of a 12:12 roof pitch
Edited 6/28/2009 8:45 pm by Huck
Pictures are worth a thousand words.....perfect.
Thanks for the clear explanation of 6-12 12-12.Now can you explain why in your diagram what must have been a section of a circle shows up here as a section of an ellipse?BruceT
Curvature of the earth. As you get closer to the poles one dimension is compressed vs the other.
So that's why it's so hard to measure the roof pitch of igloos?BruceT
I aswered the same question back in 2002, and I miraculously found the thread. Here's my answer from back then:
Start out with a 1/12 angle, which is 4.8°. This triangle is 12" across the base, and 1" on the vertical leg.
Take a 2/12 angle, which is 9.5°. This triangle is 12" across the base, and 2" on the vertical leg. Subtract the 1/12 angle of 4.8° and you'll notice that this angle has only increased by 4.7°.
Then look at a 3/12 angle, or 14.0°. That is only an increase of 4.5° from the 2/12 angle. (The "law of diminishing returns", I guess.)
Take the diference between a 12/12 angle (45°) and 11/12 (42.5°) and you'll see the difference is only 2.5°.
When you take a 45° angle and divide it in half, you're dividing an arc in half. When you deal with roof pitches, you're dealing with right triangles with different lengths on the vertical leg. (The horizontal leg is always 12")
This question comes up with regards to trusses every once in a while. There's a rule of thumb that architects like to use that "any scissor truss will work, as long as you have a 2/12 difference between the top chord and bottom chord". But that's not always true.
Take a scissor truss that's 4/12 (18.4°) on the top chord, and 2/12 (9.5°)on the bottom chord. The relative angle between the top and bottom chords is 8.9°.
But change the pitches to 8/12 (33.7°) over 6/12 (26.6°) and the relative angle is only 7.1°. The truss may not work, or may have too much horizontal deflection.
That oughta either answer your question or bore you to tears.
It's because circles are curved an lines are straight. The mathematical function for a circle is X **2 + Y** 2=r**2 (the **2 means squared). The squaring makes it not linear when figuring the angles.
Because slope goes to infiniti.
Ask your crew,"If a horizontal line is a 0/12, and a 45 deg line is a 12/12, what is a vertical line?".
So there is no whole to be half of.
a vertical line would be 12/0
infinity/12
infinity/0View Image
No, infinity over 12. You've got 4/12 pitch, 6/12 pitch, 12/12 pitch. Vertical is infinity/12. (Or infinity divided by any other positive number.)
To me, vertical is just vertical. It can't be anything over zero, as you can't divide by zero.
Bumpersticker: Get revenge - #### on a pigeon
roof ratios are rise/run. a 6/12 roof pitch rises 6 units for every 12 units of run. A 12/12 roof pitch rises 12 units for every 12 units of run. Etc.
If a vertical line rises indefinitely with no "run", then it is infinity/0. But, of course, it could be any positive number/0. While theoretically infinity/12 would have the same eventual outcome, it is faulty as a roof pitch ratio, because there would be no run on a vertical line. Which is all kinda silly, because there could be no such thing as a vertical roof rafter! You'd have to build a pitched roof on top of it!
Sounds to me like this could go the same way as some of the other math arguements here on BT.This time I ain't goin' along for the ride.
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe. [Albert Einstein]
So there's an airplane on a treadmill....
But what pitch is the treadmill at? And what percentage is the rise??
I may not be totally perfect, but parts of me are excellent. [Ashleigh Brilliant]
LOL
You have to alter your mind in some way and then think on it. You then reach a higher state of roof framing consciousness that no one understands or is willing to pay for.6/12 is for unenlightened people.
uh, no thanks
you mean like Marshal Gross?View Image
"you mean like Marshal Gross?"
Gerry Garcia?
A good read. Still have my copy.
Mathematically, anything divided by zero is "undefined."
But if it is a verticle line, then it has no pitch thus only rise no run. Thus, I agree it would be infinity over / 0 if you were trying to express it in a similar fashion to a 12/12 pitch. Look at it this way, you have a 12"/12" pitch getting closer to verticle you would have a 12" / 1" pitch then say a 12" / 1/32" pitch thus the closer you get to verticle the closer you necessarily get to 0 the slash in this instance is not a symbol of division thus there is no dividing by 0.
But roof pitch is generally expressed in x/12 notation, and the OP's understanding of the confusion is best facilitated by maintaining that notation up through 12/12, 18/12, 24/12, etc. Taken to the limit it's infinity/12.
This is just like the discussion in baseball about how many games over five hundred a team is. People are trying to mix real math with fabricated math terms that only make sense when you know the relavant deifinition.
I think I *finally* understand ;o)So please explain if 12/12 is 45 degrees and a vertical line is infinity/12 why 12 isn't half of infinity???Jeff ;o)
But I can't find infinity on my square, so I use 0/12 and flip it over.
And, infinity can't be reached!
Yeah, but an Infiniti can be pinched.
It kinda is. a 12/12 is 1/2 pitch and a 6/12 is 1/4 pitch. Old talk.
Just not 1/2 the degrees. I call 5/12, 22 1/2 degrees but it is 22.63 actually.
If you draw those lines in a 1' square box it is easier to visualize.
If you want the quick answer without trying to understand - you can use google
for 6/12 type into google -- arctan (6/12) * (180/3.14159)
for 12/12 arctan (12/12) * (180/3.14159)
