I have to ask, in the Anniversary issue pg 77 there is a hinge stick jig for installing doors and hinges correctly. There are adjustable bumpers on the jig that allow for a consistent gap on all doors. Looking at the photos the distance from the cup edge of the hinge to the case edge just doesn’t make sense. When I install doors with euro hinges I put both pieces of the hinge together then use a 1/8″ inch shim between the door and case then attach the plate to the case. Works everytime. Can anyone enlighten me on this jig? what am I not seeing?
trguy
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
Greetings t,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
'Nemo me impune lacesset'
I'd be seeing a doctor..you seem to have an endless supply of bumps.
Save a few posts, fill in your Profile, we can help!
I think he is using hinges with a very wide swing - perhaps way past the usual amount of, what - 120 degrees?
Take a look at the hinge shown just above the photo - it could just be the hinge design itself that requires the cup to be so far into the door.
Glad to see ya haven't lost a sense of humor.
