I live on a beautiful trout stream and have a fairly tough access to it as it lies 400′ below my home. There is one stretch of the cliffline that would allow a 60′ tall staircase and it is straight down. I want to get my dogs and family down safely and I want to do it as inexpensively as possible. It seems a circular staircase tied into the cliff as it was stacked up would be the easiest to assemble and pack down there. Something in steel would weather the storms and the falling rocks and debris. Anybody have any other ideas, Iwould sure appreciate them! My access now is adequate for me but unacceptible for my kids and animals-Thanks Steve
You don't have to sacrifice historical elements of a house in the name of energy efficiency.
No place to rest. Center pole needs to be
reasonably rigid in a 60 foot run. If you slip
and fall, could be a long tumble.
I would think more along the lines of a normal
switchback stair with landings. You can get
stock metal units like they use in commercial
buildings. I would think the footings and other
anchor points would be the hard part.
Or, how about a chair lift? A deck at the top,
couple pulleys, some stainless wire rope.
"Something in steel would weather the storms and
the falling rocks and debris." Yeah that's a good choice but it
really should be something like Cor-Ten or stainless steel to weather the kind
of harsh environment you are talking about with no maintenance and the arrangement
you are describing sounds like one where you don't want to have to ever maintain
the thing (i.e. paint it). Cor-Ten steel is the steel used to build bridges
and underwater construction projects. It's guaranteed to rust leaving you with
a protective rust coating, I think the stuff looks great. I love it. But you
mentioned the word "inexpensive" and your project idea doesn't at
all sound inexpensive.
As an additional footnote I'll add that for years I worked in the theatre as
a stage technician and scene painter and spent a lot of time on some very tall
circular stairs ( up to 90') that were usually used to access the fly lofts
to set blocks for stage rigging. During those years I had the coolest most loyal
dog that literally followed me everywhere. She did not like circular stairs
though even though she did go up and down them in the theatre I worked in to
everyone amazement. It was the going up that was the problem. When she was going
down she looked ahead and saw the tread she needed to put her paw on and just
went ahead no problem but going up she could see through the stairs since there
were no risers and then she realized just how high up she was and she became
hesitant slow and overly cautious. Rosalita ( named after the Springsteen song)
was the only dog in my lifetime and the lifetimes of many of my stage friends
that we ever saw even think about going up and down stairs like that so if your
planning this stair for you dogs I would test your dogs on another high circular
stairs before you spend any kind on money on it otherwise you may find yourself
carrying your dogs up and down them or having a 60' white elephant on your hands.
The 60' height is not a problem for steel but Bob's point that there is "No
place to rest." is also something to take in to consideration."If
you slip and fall, could be a long tumble." Not really long at all,
you should hit the bottom of the ravine in under a second. It just seems like
a long time when your the one who falling with all the seeing your whole
life flash in front of your eyes kind of stuff but in real time a fall like
that happens in under a second. The whole project idea sounds dramatic and interesting
but also pretty dangerous. I've done a 38' high curved stair and some of my
crew were uncomfortable with that at times.
Geez I'm thinking,... this guy must really love his trout fishing!
"Do not go where the path may lead, go
instead where there is no path and
leave a trail."-- Ralph Waldo Emerson
