Hello All,
I have a customer needing a new entry door. Existing door is 3-0 door with sidelights to make it 60 wide and 7′-6″ tall. It is set in a brick veneer wall. It seems that everything I am finding is either standard 6′-8″ or 96″ tall. both a 6′-8″ with a transom and a 96″ door will require brickwork. Anyone know of a Mfg. that has a 7′-6″ door?
Customer wanting to take advantage of stimulus rebate. If a custom door is used I am guessing it is not tested and rated to qualify.
Thanks for any thoughts you may have!
Edited 9/27/2009 2:12 am ET by garyGGHI
Look at Simpson doors I bought several 7'-6" doors from them for my victorian redo.
Daniel Neumansky
Restoring our second Victorian home this time in Alamdea CA. Check out the blog http://www.chezneumansky.blogspot.com/
Oakland CA
simpson will make doors to size.
Also several of the other makers of steel and FG will resize their doors down by request.
