##__Face Lift __##
MikeSmith | Posted in Photo Gallery on July 8, 2005 05:28am
here’s a multi-faceted job… srtip & reroof the garage apartment in the rear…
fix a leak in the cast iron vent pipe …
 fix a major leak in the primary shed dormer on the front..
 replace a single glazed french door onto the screened porch…
 and remodel the front to give it more curb appeal
some of the existing…
Edited 7/7/2005 10:30 pm ET by Mike Smith
Edited 7/8/2005 9:17 pm ET by Mike Smith
  1. MikeSmith | Jul 08, 2005 05:58am | #1
    first we reshingled the garage...
    meanwhile ... with the leaky cast iron vent pipe... we opened the ceiling..
     i expected to see a cracked joint or something.. instead i was looking at an open pipe with fiberglass insulation stuffed in it...
    wha t i think is ... 3 years ago.. when i t was reroofed  ( we bid , but didn't get it ).. someone removed a cap from the vent pipe and placed a vent boot on it...
    fine... except the pipe had been abandoned 20 years ago when the rear addition was put on  and it went no place.... in addition.... when i climbed up on the roof  to check the chimney flashing... bad.. the squirrels had eaten the corners...
    but so what ... big deal... THERE WAS NO TOP on the the CHIMNEY... how could the roofer reflash the chimney and never say a word about the fact that there was NO CAP... and
    another cast iron vent had been let into the chimney .. apparently a common thing at some time..avoided the problem of a vent flash
    got my plumber out and we snapped the old pipe and pulled it out.. also snapped the vent pipe into the chimney and rerouted it to plastic thru the roof
    here's Brad explaining what 150 of cast iron pipe will do if it lets go
    Edited 7/7/2005 11:00 pm ET by Mike Smith
    1. MikeSmith | Jul 08, 2005 06:18am | #2
      anyways ... on to the main shed dormer....
      i suspected most of the problem was on the cheeks... here's what the southeast corner looked like
      and of course .. when we stripped it... someone had very carefully installed the housewrap... and then PUT  THE STEP FLASH on top ..
       same thing with the break flash on the front... did you say flashing ?  i thought you said funnels  !
      the north cheek was fine....  mainly because they didn't change the tar paper or the old  red painted tin flashings ....
      Edited 7/7/2005 11:19 pm ET by Mike Smith
      Edited 7/7/2005 11:20 pm ET by Mike Smith
      Edited 7/7/2005 11:22 pm ET by Mike Smith
      1. MikeSmith | Jul 08, 2005 06:32am | #3
        the french doors were odd sized  a pair of  2' 3"  ...
        here's the existing.....
         naturally .. nobody makes those.. so i ordered a pair of Morgans  in 2/0 x 6/8  ( $800 each  for  $1600 the pair )
        then Scott biscuited and glued  3/4 to each edge... then ripped the  bevels with our EZ Guide  and hung them
        we thought we would have to router the jambs to make room for the 1 3/4" doors ( the existing were 1 3/8" )
        but it seems that some one had installed interior doors in an exterior jamb and nailed a 3/8 x 3/8 filler that you couldn't see... we pulled the filler out and the new doors went in perfectly
        Edited 7/7/2005 11:33 pm ET by Mike Smith
        Edited 7/7/2005 11:35 pm ET by Mike Smith
        Edited 7/8/2005 6:14 am ET by Mike Smith
  2. RogerDumas | Jul 08, 2005 12:56pm | #4
    That's a cute house - very typical of that area.  We were in Newport a few weekends ago for a wedding.  I hadn't been there in a long time.  I had forgotten how nice it is.
    I'm looking forward to your pics once again.  One question on the flasing on the dormer - If the shingles were doing their job and the flashing was installed correctly would it really matter if the vapor barrier overlaped the flashing or not?  I understand it is best as the last line of defense but it seems the water shouldn't be getting behind the shingles in the first place.
    1. MikeSmith | Jul 08, 2005 01:18pm | #5
      well... in a perfect world.. you're right..
      but i've never relied on my siding to be the only wall of protection...or to put it another way... if they had installed the flashing and tyvek correctly, there wouldn't have been a leak...
      you could leave the shingles off and no water would come inMike Smith Rhode Island : Design / Build / Repair / Restore
      1. JohnT8 | Jul 08, 2005 05:29pm | #6
        My dim-witted brain usually holds one thought in mind if I have to do or help with exterior crap:   "work from the bottom up, crap on top should be on top of the crap on the bottom".
        They obviously didn't use this principal on the dormer "repair"    ; )
        On that CI soil pipe that was leaking, I'm not 100% on why it was leaking.  You said it was open with insulation stuffed in the opening... Was it a flashing issue (rain running down the outside of the pipe)?  Or did they just teminate it into the attic..
        CI is a heavy bitch.  Get me a Fernco and some PVC.jt8
        In an underdeveloped country don't drink the water. In a developed country don't breathe the air --Jonathan Raban
        1. MikeSmith | Jul 08, 2005 08:01pm | #8
          john.... when i opened the ceiling and pulled the fiberglass insulation out of the pipe , i could see SKY...
          so every time it rained, the water would run down the pipe and onto the ceilingMike Smith Rhode Island : Design / Build / Repair / Restore
          1. JohnT8 | Jul 08, 2005 08:32pm | #9
            Sounds like the low bidder got that one.
            Keep the pics coming.  Nice to see stuff as the work progresses.
            Edited 7/8/2005 1:40 pm ET by JohnT8
          2. MikeSmith | Jul 09, 2005 02:48am | #10
            here's the outside view of that abandoned CI vent pipe...just ot the lower right of center
            also , notice the RC shingles over the hip roofs ?  see how they've been wicking water?  this siding is only about 3 years old.. they brought the shingles right down to the roofing
            also... in the corners.. they ran the steps behind the shingle course.. so it actually leaks into the walls and then runs back out.. some of it anyway
            Edited 7/8/2005 7:49 pm ET by Mike Smith
          3. MikeSmith | Jul 09, 2005 03:06am | #11
            face lift for the front.. here's the existing..
            we're moving the entry towards the middle.. and extending a porte cochere with a  gable, stepping down one riser to a platform.. then two steps to a bluestone landing
            here's the framing
            and some demo of the old concrete stoop with our feathers and wedges to split it up into manageable pieces
            Edited 7/8/2005 8:07 pm ET by Mike Smith
            Edited 7/8/2005 8:08 pm ET by Mike Smith
            Edited 7/8/2005 8:09 pm ET by Mike Smith
          4. MikeSmith | Jul 09, 2005 03:14am | #12
            here's another picture of my feathers & wedges.. bought these about 20 years ago from Barre Granite Quarry
            Scott started laying out the Sunburst for the gable end of the porte cochere
            made all the taper cuts with our EZ Guide
            Edited 7/8/2005 8:15 pm ET by Mike Smith
          5. MikeSmith | Jul 09, 2005 03:25am | #13
            rainy day today.. so Scott & Roy worked in the garage.. scott continued with the Sunburst
            Edited 7/8/2005 8:27 pm ET by Mike Smith
            JeffBuck | Jul 09, 2005 08:05am | #14
            Hey Mike ...
            up there near granite-land ...
            can U still get them fancy feather and wedges?
            Corey always thot they were cool. Couldn't locate any on my last quick local try.
            what's a set(?) of something like that run?
            The kid could really use a set ... can ya price it out for me ... if U find any?
            Jeff    Buck Construction
             Artistry In Carpentry
                 Pittsburgh Pa
          7. MikeSmith | Jul 09, 2005 03:28pm | #15
            here's a  site....
            http://www.miconproducts.com/wedges.html
            i have two sizes... one size i drill 3/4 holes
            the larger one i drill 1" holes.. the ones in the pic are 3/4 " holesMike Smith Rhode Island : Design / Build / Repair / Restore
          8. User avater
            JeffBuck | Jul 10, 2005 06:24am | #17
            Jon and Mike ...
            got those sites saved.
            Thanks.
                 Pittsburgh Pa
          9. User avater
            bobl | Jul 14, 2005 08:59pm | #25
            Check out your stone yards and mason supply places.know of at least one, retail type location, that carries them in about 5 or 6 sizes.
            bobl          Volo, non valeo
            Baloney detecter
          10. User avater
            jonblakemore | Jul 09, 2005 05:34pm | #16
            Mike convinced me to buy 8 sets last night. Here is the retailer I ordered from:
            http://www.milessupply.com/drilling.htmAnother one that looked interesting:
            http://www.sculpt.com/catalog_98/Stonetools/feather.htm
          11. JohnT8 | Jul 11, 2005 04:55pm | #18
            Sounds like the HOs have been pouring lots of $$ into that house for a while now.
            Can you duplicate the angle on this shot?  (with an "in progress" shot)
            View Imagejt8
          12. MikeSmith | Jul 12, 2005 05:01am | #19
            i'll see if i can get a panorama tomorrow.. meanwhile... back at the digs
            Edited 7/11/2005 10:03 pm ET by Mike Smith
          13. JohnT8 | Jul 12, 2005 10:03pm | #20
            Yeah, try to stand in the same spot the 'before' pic was taken.  I want to merge them.
          14. MikeSmith | Jul 13, 2005 03:26am | #21
            john.. here's my poor attempt.... i think i must have used a special wide angle lens for the first one...
            anyways.. the difference between winter & summer is sure extreme
            Edited 7/12/2005 8:27 pm ET by Mike Smith
            Edited 7/12/2005 8:28 pm ET by Mike Smith
          15. JohnT8 | Jul 14, 2005 05:57pm | #22
            kinda like those weight loss ads where the 'after' pic has the person in makeup and smiling and the 'before' pic has them slouching, scowling, and without makeup.
            Attached is how I like to visualize projects.   We have the 'before' and a 'during', but we still need an 'after'.  Tell your crew to hurry their butts up because I need an after shot  :)
          16. MikeSmith | Jul 14, 2005 08:23pm | #24
            john... that is sooooooo  cool...
             how'd ya dodat ?
            what program do you use for that ?
          17. JohnT8 | Jul 14, 2005 11:40pm | #26
            Macromedia Flash.  Give me the 'after' shot when its ready and I'll add it on.  jt8
          18. timkline | Jul 14, 2005 07:03pm | #23
            are those wood gutters like over on nantucket  ?
             carpenter in transition
          19. MikeSmith | Jul 16, 2005 05:21am | #27
            tim... no , those are aluminum gutters...we've got to replace them as part of the scope
            here's some shots from yesterday... there are 8 stringers.. so i made a short  plywood pattern / jig
            and the resulting stringers
            Edited 7/15/2005 10:24 pm ET by Mike Smith
          20. MikeSmith | Jul 16, 2005 05:27am | #28
            started laying the Ipe' 5/4 x 4  ...
            and boxing the last two posts before we wrap them with Azek
            here's the bluestone landing
            Edited 7/15/2005 10:31 pm ET by Mike Smith
          21. MikeSmith | Jul 16, 2005 05:32am | #29
            john.... here's your progress pic...Mike Smith Rhode Island : Design / Build / Repair / Restore
          22. MikeSmith | Jul 16, 2005 05:34am | #30
            here's the job sign from next door... nice huh ?
            what does "fully insured" mean to you ?
            Edited 7/15/2005 10:35 pm ET by Mike Smith
          23. timkline | Jul 16, 2005 06:20pm | #31
            that he has an agent...
          24. MikeSmith | Jul 16, 2005 11:08pm | #32
            i looked them up on  the Contractor's Registration Board...... no employees.... no comp.... what a jokeMike Smith Rhode Island : Design / Build / Repair / Restore
          25. JohnT8 | Jul 18, 2005 05:48pm | #33
            before, during, during...  I can still see Tyvek, so presumably it isn't the 'after' pic (plus there's still crap in the yard).
            Do you have a pic of your logo?  Preferably just logo, but logo on vehicle/sign if that is all that's available.
            The reason so many people never get anywhere in life is because when opportunity knocks, they are out in the backyard looking for four-leaf clovers.-- Walter Percy Chrysler
          26. MikeSmith | Jul 19, 2005 03:08am | #34
            and some more during.....
            starting to wrap the columns with Azek.......
             ouch... is that stuff expensive  !
            Edited 7/18/2005 8:09 pm ET by Mike Smith
          27. calvin | Jul 19, 2005 03:30am | #35
            Looking nice mike.
            And johns thing there is very cool.Remodeling Contractor just outside the Glass City.
            Quittin' Time
          28. ripmeister | Jul 19, 2005 08:25pm | #36
            Excellent Mike,  how are you working the Azek to do the column wraps.  I'm considering same for my porch project and am curious.  Thanks
          29. MikeSmith | Jul 20, 2005 08:28am | #37
            well... we  discussed it at length and decided we had zero confidence in gluing up a 9' miter... so we glued up a U-box, with the front face overlapping the sides... then we are nailing on back face...
             we use all SS finish nails for the Azek.... also.. this is our first Azek... we've used a lot of Koma before... but prefer the Azek as being denser on the edges.. and cleaner when routing it..
            we are concerned about expansion  / contraction.. so we're leaving the bottoms and tops short and we'll close the gaps with the pediestals & capitals...
            on the risers... we used a butt joint to  overlap the skirtsMike Smith Rhode Island : Design / Build / Repair / Restore
          30. awschmidt | Jul 20, 2005 10:10am | #38
            Mike, have never used Koma but I've hung Azek with vinyl and hardi.  I've also had concerns with relative expansion.  Did you free float the Azek around the column, or nail and glue all the way up?  How did you profile the front piece ends (leave them square with reveal or router edges)?  I've got a porch column job coming up on my current project and would be interested in a close up shot of the detail.  btw work looks great as always.
            Kevin
          31. MikeSmith | Jul 20, 2005 12:16pm | #39
            they are hollow boxes.... with about 1/16  -  1/8 clearance of the packout ... we are nailing them to the packout only at the top & bottom where the nails will be covered by the pediment & capital trimMike Smith Rhode Island : Design / Build / Repair / Restore
          32. MikeSmith | Jul 23, 2005 02:29am | #40
            here's a top view of the lower posts.. this shows the typical blocking around the 4x4Mike Smith Rhode Island : Design / Build / Repair / Restore
          33. awschmidt | Jul 24, 2005 03:57pm | #47
            thanks for the picture Mike, looking good.
            Kevin
          34. MikeSmith | Jul 23, 2005 02:37am | #41
            the 5" gutter truck showed up this morning... i met the 6" truck over the bridge on Wednesday.. so today was gutter day..
            5" on the upper roof... 6" on the lower roof
            we extended the rakes on the portecochere to hide the gutter.. here's some pics of the details
            Edited 7/22/2005 7:38 pm ET by Mike Smith
          35. MikeSmith | Jul 23, 2005 02:41am | #42
            and some of the detail work on the post trims and the sunburstMike Smith Rhode Island : Design / Build / Repair / Restore
          36. MikeSmith | Jul 23, 2005 02:44am | #43
            john... here's our Friday progress shot
            Edited 7/22/2005 7:45 pm ET by Mike Smith
          37. dustinf | Jul 24, 2005 01:27am | #44
            great pics/project.  Looks like you utilize the same portable garage that I do.  I just wish the would make them lawn pattern camo, instead of blue.
          38. MikeSmith | Jul 24, 2005 02:04am | #45
            i was tempted to bring our 7x14 trailer on the job.... but i would have had to park it on the lawn... anyways , we'll soon be outta hereMike Smith Rhode Island : Design / Build / Repair / Restore
          39. butch | Jul 24, 2005 03:38pm | #46
            That is a real good lookin porch, I'm sure the owners areproud of it. That photo where before and after are combined(I assume)I was unable to open can you post that in here likeyou do with your pictures?
          40. MikeSmith | Jul 24, 2005 06:20pm | #48
            butch... johnt8 is posting those..
            i'm just posting progress pics....thanks for the commentsMike Smith Rhode Island : Design / Build / Repair / Restore
          41. butch | Jul 24, 2005 07:54pm | #49
            yeah, I was trying to kill two birds w/one stoneJohnt8, you listening, can you post those pics. sothey show here?
          42. User avater
            jonblakemore | Jul 24, 2005 08:39pm | #50
            Butch,To view John T8's pics you need to be able to read "flash".http://tinyurl.com/3tuy
          43. JohnT8 | Jul 26, 2005 09:34pm | #51
            butch,  I could convert that flash file into a animated GIF, however it would probably get large in file size and visually fuzzy.  Flash and Java are the two primary web-animation viewers.   Their basic viewers are worth having loaded on your PC.
            for Flash, you might try going to :
            http://www.macromedia.com/
            It has a Flash animation right there on the home page, so it might prompt you to download it right there.
            If that doesn't work, here is a page from CNET with the viewer.  I thought there was a 50k viewer somewhere, but this 500k one is the only one I'm finding at the moment (take about 2 mins via dialup to download).
            http://www.download.com/Flash-Player-Internet-Explorer-/3000-2378_4-10261021.html?tag=lst-0-6
            That will enable you to see Flash animations on all websites.jt8
          44. MikeSmith | Jul 27, 2005 04:03am | #52
            all of the column moldings are Azek.... routed on a Benchdog with 1/2" shank bits
            the plinth is mitered 3/4...
            set on a PT base...
            the torus is glued up  from 1" stock ...
            idon't think this Azek is especially good for stand-alone molding... the routed edges are not fine enough.. and i still don't trust the expansion /contraction..
             i would think it's great stuff if we were painting it.. but then i might as well make it out of GP PrimeTrim.. sure would cost a lot less..
             we pay about $50 for a 5/4 x 6  x 20'
            Edited 7/26/2005 9:04 pm ET by Mike Smith
            Edited 7/26/2005 9:05 pm ET by Mike Smith
          45. MikeSmith | Jul 30, 2005 04:24pm | #53
            remember the flashing problem that was causing the leaks ?
            well , that's basically why we got this job....he's been living with that leak for 3 years..
            anyways.. here's how it looks now.. after we stripped all of the RC shingles from the shed dormer & redid all of the flashings
            we also removed the corner boards and put Grace behind them
            the other 2 pics show the same dumb flashing on the front face, with the rainscreen  (Tyvek ) BEHIND  the break flash...
            this is a shot of our typical break flash made from 8"  coil stock with a  hem and a double break to keep it compressed against the asphalt shingles
            Edited 7/30/2005 9:25 am ET by Mike Smith
            Edited 7/30/2005 9:29 am ET by Mike Smith
          46. User avater
            JeffBuck | Jul 31, 2005 09:16am | #54
            bend that the other way and it'll sit down even tighter ...
            a big "brown out" ... then a shallow "white out" ...
                 Pittsburgh Pa
          47. JohnT8 | Aug 08, 2005 11:34pm | #55
            Mike, do you have your logo in jpg or bmp form?
            Did you finish this project?  I don't have a finished photo if so.  And if not, what is the crew going to do for a week while you're away?  While the cat is away...  ;)
          48. MikeSmith | Aug 08, 2005 11:38pm | #56
            the replacement window guys are finishing today..  and the owner is hanging the lamps...
             i should have a "finished" pic tomorrow... of course .. the landscapre is still going to move the front walkMike Smith Rhode Island : Design / Build / Repair / Restore
          49. JohnT8 | Aug 08, 2005 11:59pm | #57
            Logo?  If you don't have a pure logo jpg, then just take some pics of the lawn signs and/or truck logos.  Between them we should be able to come up with a usable one.
          50. MikeSmith | Aug 09, 2005 03:00am | #58
            john .. here's our logo..
          51. MikeSmith | Aug 11, 2005 05:09am | #59
            john... that is still so cool.... next week  ( after Cal's )  i'll get you the latestMike Smith Rhode Island : Design / Build / Repair / Restore
          52. JohnT8 | Aug 11, 2005 04:18pm | #60
            See you and DW Saturday if you're still there.
          53. MikeSmith | Sep 28, 2005 12:46am | #61
            i've got to go over and take some more shots... they had their landscaper do some real nice stuff to show off the portecoMike Smith Rhode Island : Design / Build / Repair / Restore
          54. User avater
            G80104 | Sep 28, 2005 04:02am | #62
              Nice stuff Mike. Were going to have to meet in the Tav, &  discuss  Sun. Oct 16th.
          55. MikeSmith | Sep 28, 2005 06:10am | #63
            lemme guess.... something about mile high broncos ?
            how much Outbacks bucks ya got ?Mike Smith Rhode Island : Design / Build / Repair / Restore
          56. MikeSmith | Oct 19, 2005 05:08am | #64
            tate... here's your finished shot.. complete with landscaping
            Edited 10/18/2005 10:09 pm ET by MikeSmith
          57. Hackinatit | Oct 19, 2005 05:43am | #65
            Beautiful!
            Fine work as always.Troy Sprout
            Square, Level & Plumb Renovations
          58. butch | Oct 19, 2005 01:43pm | #66
            awesome!!
          59. johnharkins | Oct 19, 2005 07:33pm | #67
            that is a lovely home!
          60. MikeSmith | Oct 19, 2005 08:00pm | #68
            thank you.... of course... if the Owners didn't spring for it.. none of it would happen
            so .. god bless homeowners who want us to do nice workMike Smith Rhode Island : Design / Build / Repair / Restore
          61. JohnT8 | Oct 19, 2005 08:02pm | #69
            B & A w/ Logo.
            "Real difficulties can be overcome; it is only the imaginary ones that are unconquerable. "  --Theodore N. Vail
          62. User avater
            jonblakemore | Oct 20, 2005 12:41am | #70
            John,How long did it take you to learn that?I would love to have some of that kind of thing on our web site (and I bet Mike is thinking the same thing).
          63. MikeSmith | Oct 20, 2005 04:35am | #71
            you bet your bippy..
            tate.... that's way beyond cleverMike Smith Rhode Island : Design / Build / Repair / Restore
          64. JohnT8 | Oct 20, 2005 05:56am | #74
            Mike, feel free to use those Flash files however you'd like.
            It's like burgoo.  Everyone throws a little something into the pot and the result is that everyone gets fed.  The time it takes me to throw one of those Flash files together is insignificant to the time I save when I get a good piece of advice hereabouts.  And considering I've got some pretty good sized projects coming up (good sized for me), I figure I'm taking more out of the pot than I'm throwing in.
          65. JohnT8 | Oct 20, 2005 05:37am | #73
            Most of the SWF's I'm posting here don't even touch the tip of the iceburg.  You get a good graphic artist who knows Flash and they can do some amazing stuff.  And from a computer geek point of view, its just amazing how small the file size is.
            But to answer your question, you can probably pick up any basic Flash book and learn how to make a clip like the ones I did for Mike.  Its just a matter of applying different chapter lessons into a single file.
            I try to stay on Mike's good side, cuz he's one of those crusty old-timers who seem to have a vast storehouse of construction knowledge.  :)
            What are you trying to make a flash out of?  What kind of site?
          66. User avater
            jonblakemore | Oct 21, 2005 12:19am | #75
            I'm thinking about sopme flash our website and possible a powerpoint presentation that I would use when meeting with clients.Flash can be impressive but often it seems they want sizzle without adding any real content. The before/after stuff is great for the visually-oriented people.Would you be interested in converting some before/after shots for a fee?
          67. JohnT8 | Oct 21, 2005 12:55am | #76
            I agree, there is a lot of garbage flash out there.  Typically advertising something or other.
            How many Flash clips were you thinking of, Jon?   Like I said to Mike, BT is like a big pot of burgoo where people throw in whatever they have to contribute.   If you just need a couple or so, I can just throw them together for free.   Just part of my contribution to the pot.
            If you need a bunch of them... well, we can probably come up with some arrangement.  Just keep in mind, that 1 out of 10 people (or so) might not have the flash plug-in loaded on their PC, so if its on a website you probably want to support it with JPG's.
            Here's my Yahoo address if you want to email me:   [email protected]
          68. MikeSmith | Nov 24, 2006 03:46pm | #77
            this house sold for $1.2 mill  early this year... the Owner gave us a lot of credit for  the selling priceMike Smith Rhode Island : Design / Build / Repair / Restore
          69. User avater
            intrepidcat | Oct 20, 2005 05:16am | #72
            That's almost as impressive as the house work.
             Hard Eight Bar B Que, Brady, Texas
            "Always bet the Hard Eight!"
      2. RogerDumas | Jul 08, 2005 07:24pm | #7
        Mike,
        I understand and agree.  It just seems that if water is getting behind the shingles there are other problems as well...
Picture-Perfect Pergola
