A/C is Leaning
mrfixitusa | Posted in Energy, Heating & Insulation on July 1, 2008 05:17am
I watched a home inspector do his thing today and he “wrote up” the outside A/C unit because it was leaning.
He told us how to level it and get it straight and plumb and he said the leaning causes wear and premature failure of the compressor
I told him most A/C unit I have ever seen are leaning. Some pretty badly
Agree with the inspector? Disagree?
Edited 6/30/2008 10:18 pm by mrfixitusa
  1. renosteinke | Jul 01, 2008 05:19am | #1
    Well, he's correct about one thing ... the A/C is supposed to be mounted on a level pad.
    1. segundo | Jul 01, 2008 06:13am | #2
      a lot of them have a little lean on purpose, to move the condensate away from the unit/structure
      1. renosteinke | Jul 01, 2008 06:22am | #3
        Silly me ... I thought that's why they had piping and catch pans.
      2. DaveRicheson | Jul 01, 2008 02:38pm | #4
        Huh?
        I took it he was talking about the outside condenser unit. Where do you get condensate there?
        The real issue with a sevearly leaning compressor/condenser unit occurs durring the winter months. The refrigerant gas tends to migrate to the lowest and coldest point in a line set or outside coil. It also tends to take the oil with it, so you could potentially create a low oil situation in the compressor durring start up. It tends to happen more in long runs of line sets and unit with high lifts in the line set, rather than in the condenser itself.
        Outside condenser sets are designed to be self draining for rain water. Maybe if one were tilted far enough over and junk built up insde the coil, it could pond some rain water, but not much. It would still run out through the coils.
        Me thinks the guy was just trying to show someone he knew something.
        1. rasconc | Jul 01, 2008 05:29pm | #5
          A heat pump will have condensate at the condesnser in winter operation.
          1. roger g | Jul 01, 2008 07:11pm | #6
            Yes, but no condensate pan that I have ever seen. It just drops and drains wherever.roger
          2. rasconc | Jul 01, 2008 07:58pm | #7
            Still probably not a bad idea to have the pad ever-so-slightly tilted away from foundation I should have added.
          3. segundo | Jul 01, 2008 08:51pm | #8
            thats what i was talking about, don't hurt a thing and more better to have moisture move away from structure.
    rjw | Jul 01, 2008 08:55pm | #9
    The info I have seen from the manufacturers generally "allows" up to 10degree tilt.
    Remember Mary Dyer, a Christian Martyr (Thank you, Puritans)
    http://en.wikipedia.org/wiki/Mary_Dyer
    May your whole life become a response to the truth that you've always been loved, you are loved and you always will be loved" Rob Bell, Nooma, "Bullhorn"
  3. Tim | Jul 01, 2008 09:05pm | #10
    Slight skewing of the unit has no effect on the unit perfomance or longevity. So, how much is "slight"? Less than 15 degrees. Anything more than that looks bad. The motor shafts are all vertical and the slight lateral load might decrease the lifespan by a few hours.
