DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted part you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprint whorls
and hard-earned guitar calluses in about the time it takes you to say,
“Ouch….”
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Also used to round off bolt heads. If nothing else is
available, they can also be used to transfer intense welding heat to the
palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub you want the bearing race out of.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new disk brake pads, trapping the jack
handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward
off a hydraulic jack handle.
PHONE: Tool for calling your neighbors to see if he has another
hydraulic floor jack
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog
off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps off in bolt holes you couldn’t use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry-bar that inexplicably
has an accurately machined screwdriver tip on the end opposite the handle.
TROUBLE LIGHT: The home mechanic’s own tanning booth. Sometimes called
drop light, it is a good source of vitamin D, “the sunshine vitamin,”
which is not otherwise found under cars at night. Health benefits aside,
it’s main purpose is to consume 40-watt light bulbs at about the same
rate that 105-mm howitzer shells might be used during, say, the first
few hours of the Battle of the Bulge. More often dark than light, its
name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; but can also be
used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts last over tightened 58 years ago by someone at ERCO, and neatly
rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50¢ part.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts not
far from the object you are trying to hit.
MECHANIC’S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on contents such as new seats, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage
while yelling “DAMMIT” at the top of your lungs. It is also the next
tool that you will need.
EXPLETIVE: A balm, usually applied verbally in hindsight, which somehow
eases those pains and indignities following our every deficiency in
foresight.
#160;
BATTERY DRILL: An expensive, some say an indispensible item for any toolbox. After a short period of steadily decining power, another set of batteries can be purchased for the same price as a new drill.
Circular Saw Blade Guard:
A well intentioned devise that creates friction during the most important parts of what ever cut you are in the middle of. This friction combines with frustration and results in a F**ed cut that you cannot use. Also designed so as to be in the way when trying to change the blade.JT
POST HOLE DIGGER: an excellent tool guarateed to locate every large rock, boulder, electrical cable and gas line buried more than 2 feet below the surface of your backyard.
HARDWARE STORE: Similar in function to a black hole, it warps space and time so that a 5 minute trip actually take 90 minutes. It affects men mainly, they seem to walk in and come out some random time later with less time and money than they had when they went in. Its nearest phenomological relative is the SHOE STORE.
BIG BOX STORE: Similar to HARDWARE STORE, except that the time/space/cash warping effects tend to follow you home. Lumber products purchased straight at the store will warp into knots after they are brought home. Scientists believe this may be cause by the Wet Hole transportation effect on the lumber (like a Worm Hole through space, except that it is raining inside this transportation corridor the entire time). See if the next time you leave a BIG BOX STORE you feel like you just stepped out of a big Wet Hole.
Also a CRX fanatic!
Thanks for posting that, it was hilarious. Laughed out loud all by myself here over a couple of them..... They're so true that it's almost not funny.
