ABC’s of slab on grade layers
| Posted in General Discussion on May 31, 2001 04:46am
Hi !
I’m a new owner builder (with pro help) and we are about to back fill the frost footings. My question at this point is I am getting stubborn about wanting to do this right. The south wall is all high performance glass and I will have ceramic tile as the finished floor surface. Does it make sense to use more stone fill on that side of the house ? Under a slab does it really act as a heat sink ?? I did the proverbial garage house last fall and lived through a tough Minnesota winter and the windows really soaked up the heat nicely. I went from about 9 a.m. to 11 p.m. without the boiler kicking in (hot water floor heat in a 2″ slab over subfloor). The next section will have the same heat source but on a slab (no basement).
Could I beg for your own “sandwich” layer advice ? This is gravel heaven so there’s plenty to be had.
Thanks…this is a wonderful board to have discovered…been adicted to the magazine for years !!
pseko
  1. pseko | May 31, 2001 04:46am | #1
    Hi !
    I'm a new owner builder (with pro help) and we are about to back fill the frost footings. My question at this point is I am getting stubborn about wanting to do this right. The south wall is all high performance glass and I will have ceramic tile as the finished floor surface. Does it make sense to use more stone fill on that side of the house ? Under a slab does it really act as a heat sink ?? I did the proverbial garage house last fall and lived through a tough Minnesota winter and the windows really soaked up the heat nicely. I went from about 9 a.m. to 11 p.m. without the boiler kicking in (hot water floor heat in a 2" slab over subfloor). The next section will have the same heat source but on a slab (no basement).
    Could I beg for your own "sandwich" layer advice ? This is gravel heaven so there's plenty to be had.
    Thanks...this is a wonderful board to have discovered...been adicted to the magazine for years !!
    pseko
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
