above subfloor radiant heat
lancepoo | Posted in Energy, Heating & Insulation on October 15, 2011 11:21am
I would like to install pex tubing above the sub floor, sandwiching the tube with 3/4″plywood cut at a bevel.  Are the aluminum plates placed over the tubing and under the plywood strips?  Where can you buy the aluminum plates?  I live in British Columbia, but very near Seattle, or Portland.
  1. calvin | Oct 16, 2011 07:38am | #1
    lance
    Here's what we did a couple yrs ago.  No bevel, the plates fit in the gap between the rips.  The arcs were routed out using a half or 5/8's bit, the drops were then placed inside the turns, leaving the gap for the hose.
    Get the plates b/4 you lay this out so there's a nice fit.
