I am looking for a convienient way to leave an access panel to the motor of a jacuzzi tub I am installing. I built a 2×6 deck, will be using durarock backer board, and the entire base will be tiled. Is there any good way to do this and still leave a nice, finished tile appearance?
Schulter has the exact product, pre-made for you. It is magnetic.
http://www.schluter.com/english/products/2002/sectionb/overview-b/section-b.html
Boris
"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1927
Good idea from Boris. Depending on the color of the grout, you could use silicone instead of grout for the panel edge. This would allow for easy access as you would only need to cut the silicone to allow the panel to be removed.
We frame the access panel into the tub surround and mount magnetic "push" latches, like you see on stereo cabinets, to the panel. The tile installer cuts the tile backer to fit on the panel and covers it with tile. Instead of grouting those tiles, we use sanded caulk that matches the grout color. When access is needed, you cut the caulk, push on the panel, it will pop forward and can then be pried out. TCW Specialists in Custom Remodeling.
I would have never thought to put sand in the grout to get the right texture. Next time I need to do such an application I'll try it. Thanks
Tim, that sounds like the way to go, thanks for the help.
