access to dryer/washing machine under countertop
rantipoler72 | Posted in General Discussion on June 27, 2012 11:25am
Any pointer or things to consider on water/drain/electric/exhaust vent access when installing washer and dryer under a counterop? It seems like access to the hookups would be a challenge with a slab of granite/concrete, etc over them and cabinets built around. For example, how do you get water off quickly in case of a leak? Thanks
  1. DanH | Jun 27, 2012 11:44pm | #1
    The hard part is connecting the dryer outlet.  Water can be turned off with remote valves -- they don't need to be right behind the washer.
    If I had to do this, I'd put the pair on a trolley of some sort.
  2. k1c | Jun 28, 2012 09:34am | #2
    I would connect the machines for easy access, that is, normal way, then put a rolling counter over them.  Make sure there will be enough room to roll the counter out and away.  Stool on wheels also is handy for moving the laundry out of front  loaders.
Pressure Washing Made Portable
This electric pressure washer is compact, lightweight, and easy to maneuver.
