Access to plumbing for a soaking tub
| Posted in Construction Techniques on May 23, 2002 11:58am
In our current remodeling job, we’ve designed a new soaking tub (standard 32″ x 60″), with shower and tiled surround to back up to a wall that does not allow us to get an access panel directly behind the tub drain/overflow and water supply. I’ve contacted our local jurisdiction responsible for the plumbing inspection and have been told that an access panel is not required as long as there is an all glue waste and overflow.
What do you think? Would you try to reconfigure the design to get an access panel in at all costs anyway? Or would you live with not having one? Also, what would you most want access to – the waste and overflow? the supply lines to the shower? etc.
Thanks,
Hisao Yatsuhashi
  1. 4Lorn1 | May 24, 2002 01:21am | #1
    This is a common problem. I can think of 3 or 4 houses that have hot tubs, I would think these would absolutely demand access, without access. All were inspected. In one case anyone making a repair has a choice between tearing out some of the 2x2' Italian marble on the three sides or hammering through the brickwork on the exterior wall.
    In one case I was wiring the new house. When I found out that the GFI we used would not be accessible I dropped it down into the crawl space. Had I not been there the tile guy would have happily tile boarded and laid tile over my box. I tried to get the builder to arrange access but he refused so I did the best I could. Someone will have hell to pay trying to make repairs. There is a motor, heater, air switch and assorted plumbing that will break down and will need work. The whole thing seemed short sighted to me and left a bad taste in my mouth.
    Anyone have any ideas as to how to get builders to provide access?
    1. Murphyryan | May 26, 2002 11:43pm | #2
      Access is not required by code as long as there is no electrical equipment involved.  If installed by a craftsman there is little if any need of acccess.  Any electrical equipment must have access for service and repair.  In CO a faceless gfic reset must be placed in the same room as the tub spa more that 5 feet from the tub and above the floor.  Check with your electrican for details.
