Acrylic stucco coating – omegaflex – application question
Denver95 | Posted in Construction Techniques on April 2, 2011 05:34am
I have used this product in the past, always troweling it on. I notice on the bucket that it can also be sprayed on. What kind of sprayer is used for this? Would a drywall texture sprayer work? If it matters, I am using the “coarse” grade, which is textured with sand.
  1. bob@stucoflex | Apr 14, 2011 07:06pm | #1
    Spraying Omegaflex
    I would encourage you to contact Omega regarding proper spray application of their product, however I have sprayed a very  similar product and it can be applied out of a drywall texture sprayer. Optimum air pressure should be 70 pounds plus at the tip of the gun and remain consistent, This may require an air compressor with 12 -14 CFM minimum or more depending on the length and diameter of the air hose.  There are bigger machines as well if you have a large job.  Your arm may get tired if you have a lot of spraying.
Old House Air-Sealing Basics
