Adding antifreeze to a hydronic system
I’ve never had to do this before. How do you add antifreeze to a radiant heat system? Is there some type of injector that can be installed in the manifold to add it?
THANKS
THANKS
Listeners ask about affordable home builds, installing a patio on foundation backfill, and dealing with peeling paint on masonry.
Just watched my plumber do two boilers last week. He uses a little pump with a hose fitting on it, screws it onto the boiler drain, opens a valve somewhere down the line, pumps ten gallons in, ten gallons come out at the other open valve.
Steve
