I am in the process of adding baseboards to most of the rooms in the 20 year old house we purchased 6 years ago. Most of the rooms have wall to wall carpeting without any baseboeard. We are also replacing the carpeting. The carpet salesman says I should want until the new carpet is installed and then put the baseboards on top of the carpet. I have never heard of this. All the baseboards in your previous homes were resting on the underlayment. I would think that with the baseboard on top it the carpet, it would be difficult to remove and install the carpet the next time it needs to be replaced. Has anyone seen baseboard installed down tight on the carpet instead of down tight on the underlayment?
With the advice of our carpet installers, we keep the base approx. 3/8 - 1/2 inch off the floor. This gives the carpet installer enough room to tuck the carpet under the base. Then if you want a shoe molding can be installed after the carpet, but now we rarely use a shoe anymore.
Welcome to BR ERV
There's really no bad way, first or last. But what I have always done is install my base first using a spacer to hold the baseboard off the floor. The spacer should be a little less than the carpet and pad. This also helps by spaning irregularities in the slab. Prime and first coat before carpet installation to save time. They may beat it to death during installation but the first two steps will be done. Then tuck your masking between the carpet and baseboard using a putty knife and finish.
Voila! A nice job done.
Echoeing JAGWAH, painting base once the carpet is in is a time-consuming pain. Life is just so much easier if the base is set down about a third of the pile, primed and painted, and then you tuck the carpet under the base with a stair-tool when you install (the plastic stair-tools produce a lot fewer scratches on the base BTW). From my observations, I've concluded that carpet tucked under the base seems to be much tighter and less likely to form those little waves (aka: folds) that require the installer to come back a year later and re-kick the carpet.
Phill Giles
The Unionville Woodwright
Unionville, Ontario
Edited 9/15/2003 10:36:28 AM ET by Phill Giles
I'm just going to agree with everyone else.
Baseboard first, but raise it that 3/8 to 1/2 above the floor.
The gap gives the layer a nice gap to put the carpet edge under.
One other thing is that if they lay the carpet first, the tack strip will be directly under the base and virtually impossible to replace carpet without removing all the base.
The guys that lay our carpet also say that it is much easier on them because they don't have to be quite as careful about where they place the stretcher.
And let me also echo the Welcome to Breaktime.
Welcome...Welcome, Welcome
Lets keep it unanimus....baseboard prior to carpet installation....go with the spacers as well.
J. D. Reynolds
Home Improvements
"DO IT RIGHT, DO IT ONCE"
one more vote for base installed before carpet - space mine 3/8" off floor
I put the carpet down first then the base,
every thing gets screwd down with dry wall screws : base, carpet, shoe
Cabinets, three tab shingles for siding
blue tarps for roofing
Mr T
Do not try this at home!
Mr T
May I respectfully request that you get out, OUT, OUT!!!!
Here I was,
reading along,
blissfully enjoying the only thread in all of the Tauntonian Kingdom
where everybody was in agreeement on something
To the point it was sounding like a peaceful chant for the inner tipi
and then you come along and ruin my day.
Learn to put the baseboard down first with a gap for threads like thee rest of us by dangnubbit!
Or
Get Out!
Sheet rock screws indeed!
Youse younguns
Cain't teach you nuthin'
Mutter
mutter
Spit and sputter...
Buy you books and buy you books,
and all you do'
is lick the dirty pictures!
What am I gonna do?.
Just doin my part to liven this place up and get you over 10KMr T
Thirteen to go as of this post. Bells and whistles might go off tonight.
Have a great day..
good to hear you're doing things by the book
hope you are going with the 19.2" on center screw schedule on that base
