Guys,
Looking at a home which the owner wants to add a porch in the “corner”. House is L shaped with gables on each end and a valley where the porch will go on the inside of the L.
Any thoughts or pictures of a way to make this look good?
Mike
Guys,
Mike
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
Mike,
So the problem is how to design the roof?
That's a tough one for a one story house. I've been asked to design something like that for someone but they never had me build it. I'd say, start your deck lower than you normally would. Attach your ledger to the foundation instead of the rim board. Keep the ceiling height low, like 7 feet. Then finish the roof with a super low pitch and install rolled roofing (which is made for shallow pitches). This keeps the finished roof height of the new porch underneath your existing gutters.
Hope that helped.
Mike,
Thanks...good idea. Its a single story ranch and of course they'd like the ceiling height to be as tall as possible. Urgh.
Mike
...they'd like the ceiling height to be as tall as possible.
"Cathedral" ceiling, perhaps?
J. D. Reynolds
Home Improvements
Peachy. If you merely match the existing fascia & soffit and "turn" that out to match the new porch roof, the "problem" is not really ciphering up the roof lines, it's supporting that "corner" out there. Last thing needed with the atypical valley conncetions is to have any difference in foundation movement.
So, what to do?
Well, how about doing this as a bit of "pavillion"? Have the porch free-stand in the inside corner. Bring the roof in as a four-sided hip, and gutter it right around, tucked just under the exisitng fascia/soffit. Using a dissimilar roof material will help this.
Inside corners are a real pain for these things. You can't really just extend the roof lines out, as that moves the peak right up. It's tough designing, and the compromises make for tough building, too. I don't envy you this at all.Occupational hazard of my occupation not being around (sorry Bubba)
sounds like a great opportunity for a hundred guys to kibbitz..
if you post two elevation pics of the exterior, i bet you get some good suggestions
Mike,
Good call. I'm actually going back over to the house later today so will take some to post here.
Mike
See ya later then
Struggled with a highly similar situation on my own home. Had a two-story on the left side of the L, one story on the right, 12/12 roof on each of them. Left side had a window in the 2nd floor set too low (1905 build). It was obvious the previous owner had the same problems, they opted for a flat aluminum roof, ugliest thing ever. I could not find a decent solution, either. Finally decided to build the porch with a flat roof (pitched 1/8" per foot), EPDM roofing, made the roof a deck for the master bed room, the too low window becomes a french door, and turned a design problem into a feature.
Don't know how this helps you, other than the suggestion, build it flat, put a balustrade on it, and act like it's a balcony.
You could build the roof relatively flat, with an EPDM (or equal) roofing..
Then detail the porch to look more like a pergola. Exposed rafter tails, etc..
mike this is a little rough... basically
add your porch room in the corner , and build an overlay roof, hipped
then move the back hip up until it forms a level ridge
you now have two valleys and no dead valleys
Edited 2/9/2007 3:31 pm ET by MikeSmith
Edited 2/9/2007 3:32 pm ET by MikeSmith
Edited 2/9/2007 3:35 pm ET by MikeSmith
here's an elevation view
Edited 2/9/2007 3:39 pm ET by MikeSmith
Mike,
What are the dimensions of the existing building and how far out will the porch come/ Will the porch come out to the end of the house on one side?
I frame porch roofs like this all the time.I frame a shed roof with a least a 4/12 pitch that hits wherever at the existing roof line. That line carries over to the existing valley. From there you make a NEW valley that continues to the top of the new fascia line where it hits the existing fascia line if they have to meet.
Sometimes the fascia lines don't line up. If that's the case, wherever the plane of the new shed roof hits the existing roof at the top is where the new valley will start and go op to where the new shed roof intersects with the existing valley.
Guys,
Thanks for the great replies, graphics and all! Awesome.
Dimensions yet to be determined based on what the homeowner can afford. But some excellent desgin concepts to begin with.
Mike
