Adding on to a pole barn
| Posted in General Discussion on April 5, 1999 09:14am
I am planning on adding a 16 ft addition to a pole barn I have. It will be built on a slab. My question is this: How can I best tie the addition and the original building together? It is There is a 1 foot overhang. I am using trusses on 8 foot centers with purloins.
Thanks Rich
  1. Guest_ | Apr 05, 1999 08:41am | #1
    Are puloins like steakloins?
    J
    1. Guest_ | Apr 05, 1999 09:07am | #2
      *Jack, I wanted to say the same thing but hesitated in fear of starting another fred hates gabe hates fred string.As for you rich, it seems to me that you would just knock off the overhang on that gable side and add on.Pete Draganic
      1. Guest_ | Apr 05, 1999 09:10am | #3
        *Are you adding a "tip out" to a square or rectangular pole building? In my experience pole buildings arent built on slabs, slabs are poured in the existing buildings.JonC
  2. Rich_clinton | Apr 05, 1999 09:14am | #4
    Thanks Rich
Pressure Washing Made Portable
This electric pressure washer is compact, lightweight, and easy to maneuver.
